08 Ford Edge engine codes - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 03-18-2013, 04:00 PM
BFace805's Avatar
BFace805 BFace805 is offline
BFace805 is starting off with a positive reputation.
Hey folks,
I have an 08 Edge with 51k on the engine. I've got two codes, P0011 and P0016. One is a cam sensor and another is a cam actuator. Should this be covered under the powertrain warranty? GM covers the cam actuator under their powertrain warranty but Ford told me that it's not covered.
Old 03-18-2013, 07:45 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is online now
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
It should be covered depending on the warranty start date. Send me the VIN and I can check OASIS
Old 03-19-2013, 05:02 PM
BFace805's Avatar
Ford already checked the status of the drivetrain warranty. I'm good for another 11 months of 9,000 miles. My question might have been vague. I was wondering if P0011 and P0016 should be covered under that warranty. It's a fairly cheap ($380) repair but one I'd like to avoid paying if I could.
Old 03-20-2013, 05:18 PM
Those codes are for the cam phasers. I just finished doing a set today. Since its covered take it in and let them fix it. The TSB is 11-6-1. I pull the engine to do them since the timing cover and both valve covers have to come off and it's a lot easier getting to everything with the engine out.
Old 03-20-2013, 05:34 PM
BFace805's Avatar
I thought it was going to be cam phasers too but they told me it was just two sensors. The cam actuator and the cam position sensor.
Old 03-20-2013, 05:38 PM
BFace805's Avatar
Oh, and they are not the ones that ran the codes. Sears did because I just don't have the money to pay Ford to check the code and tell me it's not covered under warranty.
Old 03-21-2013, 06:28 PM
BFace805's Avatar
Actually read the TSB. It's exactly what I thought. Thank you.
Ben
OBD readings p0013,p0014 hokymn 1999 to 2016 Super Duty 2 05-05-2015 09:38 AM
2004 f150 Limp mode P0722 PO713 faults jeremeh83 2004 - 2008 F150 4 06-04-2013 10:48 AM
warranty for IWE system/auto hubs riverns 2004 - 2008 F150 10 01-23-2011 05:49 AM
powertrain warranty? MRUGG 1999 to 2016 Super Duty 1 09-27-2010 02:25 PM
Rear Differential leak jay427 1999 to 2016 Super Duty 5 12-09-2008 09:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
