how much primer - Ford Truck Enthusiasts Forums
how much primer
Old 03-18-2013, 01:33 PM
Eliduc Eliduc is offline
Eliduc is starting off with a positive reputation.
how much primer
I'm painting the cab on my 59 f 100. I am putting primer filler over epoxy. How many coats of epoxy and filler should I spray and how much should it take. it will probably be going onto bare metal. The guy at the paint store told me a quart of Nason epoxy would cover a bus. I'm not painting a flarking bus only a P.U. cab. Is a half gallon of mixed epoxy enough. I notice on the spec sheet that it says the epoxy can be used with any top coat system. Is it safe to use another brand primer and base coat/clear. has anyone used the TCP urethane?
Old 03-19-2013, 07:41 AM
economan economan is offline
economan is starting off with a positive reputation.
May I suggest something Eli....
Instead of using 2 products, i.e. epoxy then filling primer why don't u look @ a product called polyester primer. I have used if for over 10 yrs w/ great results.
It is available under the names "Evercoat FeatherFill G2" "Z-Chrome" ... Sherwin Williams also offers it but i can't recall the product number. is available in gal & qts.
$65-80 gal. here in Canada this includes hardener $18-20bucks for a qt.
This product will easily fill 36 grit sander/grinder marks. and sands super easy. and NO shrinkage. reduces & cleans up w/ acetone
i reccomend a guide coat to make sure u eliminate all marks dings etc underneath.
I just usually just spray whatever scrap (non hardener) basecoat i have around right after i finish spraying the primer(saves cleaning the gun 2wice)
Only caveat is it's slow drying time 12-24 hrs depending on shop temps. before it will sand easy without clogging paper. I have used it under all different types/brands of topcoats.
Just an alternitive to look @, any more ?s lemmee know
Mikie
near ottawa canada
58 M-100 panel & 64 econoline p/u
Buy paint while you still can Gicknordon 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 10-17-2015 07:23 AM
Filler over epoxy 67nukeford Paint & Bodywork 9 05-07-2015 09:13 AM
Filler over primer. Epoxy primer. etc etc Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 02-06-2015 10:42 AM
Tentative painting strategy jvmcc Paint & Bodywork 3 09-13-2013 11:07 PM
Primer question.... avf100 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 08-14-2013 06:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
