Cost of painting - Ford Truck Enthusiasts Forums
Cost of painting
Old 03-18-2013, 11:44 AM
K9sicem's Avatar
K9sicem K9sicem is offline
K9sicem is starting off with a positive reputation.
Cost of painting
This may seam like a strange question and it may be hard to answer too. But here it goes with some background info first. The truck is in primer. Only a few small areas need work and then block sanded. Both the cab and bed. The bed is off the frame. The fenders and doors will need final adjustment to get the gaps right. There is no trim or other parts on the truck that will need to be removed or taped. I will put it all back together after the paint is done. I will deliver and then pick up both body parts. I am not looking for a show paint job. The truck will be satin purple. I just want it to look nice and not look like it was done in the back yard. What would a reasonable cost be to paint the truck if I supplied all the materials. I have a friend and his friend coming to look at the truck and show me his work.
Old 03-18-2013, 12:32 PM
Beechkid Beechkid is online now
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
I would swag.......$2500 plus body work (assuming $1k for materials)
Old 03-18-2013, 04:47 PM
Damifiknow's Avatar
Damifiknow Damifiknow is online now
Damifiknow is starting off with a positive reputation.
I think if you did all the work, bought the material and paid a guy just to paint, $1000 bucks is more than fair but what about wet sanding and clear coat?
Old 03-18-2013, 06:02 PM
IMHO, I prefer a single state paint....it just looks sooo much better (although it does cost a few hours of labor for wet sanding & polishing) as compared to BC/CC where you just spray, buff & go in most cases!
78 Ford f250 restoration questions honda_guy4 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-28-2014 04:10 PM
Advice for purchasing an F4 or bigger truck Majeztic 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 10-08-2013 01:35 PM
$12,500 cost summary for 1962 restoration to daily driver. old broke prospector 1961 - 1966 F-100 & Larger F-Series Trucks 34 07-10-2013 12:30 AM
What to do? egarage 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-15-2012 12:59 PM
Buying advice needed on an '80 F100 fiftyfordfloored 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 08-11-2008 10:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
