Mid-60's mustang gas tank install
on
what Gary said..... drill/drive/grind them out and replace with same sized (or one over) grade 8 bolt with a locking nut and threadl ock -red. Take out the cross member and get on with it. The shackle will never know it's a bolt or rivet if you tighten it properly and probably not then...
I never replaced the cross member but I did install a trailer hitch at the rear that does the same thing...
later
John
later
John
You're on the right track. just grind off the rivets and slide the crossmember to the end of the frame and bolt it in. Replace the rivet you removed from the spring hanger with a grade 8 bolt. Build the 1" square tube frame as outlined in the link you posted and mount that to the bottom of the frame rails.
You might need to trim about 1/4" from the bottom inner edge of the frame rails to get the top of the tank to fit between the rails.
1bikenerd
15
11-09-2015 09:22 AM
55forder
04-05-2005 04:27 PM
timken444
12-16-2004 12:30 AM
