what could it be?
what could it be?
Alright i've got a 78 f150 with the 300 i6 stock carb. When i tap the gas pedal it either hesitates or just dies. If I ease into the carb it acts like nothing is wrong at all. If i'm driving in 3rd or 4th gear and tap the gas petal, it does not hesitate. It seems to do it when it isn't under much of a load or any load at all. It also seems to get a little better when it warms up but it's still bad. I've adjusted to it and drive it almost daily but its still a pain in the @$$. I have given up trying to diagnose the problem since I feel like it could be any number of 150 things. Anybody have this problem before? Any advice or help would be appreciated.
To the others, where is a good location for my vacuum advance line?
The motor never had EGR. It is an 82 motor with all 78 external parts ergo eliminating the problems associated with removing the EGR.
I already thought about the timing factor. I will most likely time it with a vacuum gage, but I'm not entirely sure how to do that - where should I attach the vacuum gage, what am I looking for as far as readings and etc.
Thanks guys the help is appreciated
yes that is correct.
To answer your vaccum gauge question see here Classic Inlines - Tuning with a Vacuum Gage
You still might have to recurve the dizzy
Ford Truck Enthusiasts Forums - Search Results
The EGR plate may have been optional in 78, but the motor that I took the parts off of did not and it is a 78. The Dizzy probly does need a recurve, but I don't have a clue how to do that or where to get the kit. Links or info for that would be awesome. Thanks for the Vac gage link and to everyone else.
On the EGR it was more than likely already removed on the 78 motor there are several threads on removing the EGR on the 300 six and the pros and cons .. My suggestion is to read through them and make sure the EGR removal was completed properly so future damage to the motor won't occur.. Here is good article on the whole timing process and recurving and how it's done and the reasons why ..
Classic Inlines - Ignition System & Timing
Hey thanks a ton. I'll look into the recurve. I rebuilt the carb and timed the engine and it misses while cold, but when it is warm it runs better than it ever has in all the years that it's been in the family. almost NO hesitation, plenty of power, and I've been calculating the mileage in the high teens. Thank you.
1986F150six
04-20-2015 09:32 AM
1986F150six
08-03-2011 01:32 PM
GELGIN58
07-26-2008 05:01 AM
Supercab
10-10-2000 12:40 PM
