Spartan tuner and EGR Delete???'s
#61
As far as the EGR coolers they are junk period nothing better then the 6.0's had, it not a matter of if there going to fail its when there there going to fail and if your one of the not so lucky guys your engine will get scraped from a hydro lock. If your stock its hand down worth the investment to upgrade the EGR coolers to bullet proof cooler the design is simply what ford should have done to begin with. If urn considering a block off delete id just delete the entire cooler its about the work IMO.
#63
#64
With ambient temp around 90 degrees this is wat i saw with my stock turbos stock tuning
empty crusing 75 down road around 550-600
loaded say pullin a trailer around 17,000 about 700-800 on the flats
loaded say pullin a trailer around 17,000 about 1150-1250 up a 6% grade (1270 is the max i ever saw with stock tuning)
#65
<style> <!-- /* Font Definitions */ @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Cambria; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> Horsepower mean nothing when It come's to the need of a waste gate or not. The main reason for a waste gate is to keep the turbo's from over speeding which results in an extreme loss of efficiency, and EGT's going thru the roof. The 6.4 turbo's are out of their efficiency zone at around 40 PSI anyting higher does becomes inefficient horsepower.
I think the prudent course is to keep a close eye on the coolant, if it starts to disappear without an external leak, then you have an EGR problem, correct it then if needed. Otherwise, leave the truck close to stock so you can return it to stock when ready to sell. Modified trucks are hard to sell.
#66
Not to pick a fight here but, I've been on this forum and read most every post for 4 years and I do not remember a failed EGR cooler. Of course I may have missed or forgotten a couple, but the problem is far from epidemic like it was with the 6.0s.
The shop I use does nothing but powerstrokes 24/7, and they say it's a rare occurrence. Of course as soon as I hit the post button I'll become one of those rare occurrences . Seems to be the way it goes for me. That way my mouth gets to make me look like an idiot AND cost me money, all at the same time. Hehe.
#67
I haven't heard of much negative things about 6.4 EGR systems in general, compared to the 6.0.
The EGR coolers must be a hell of a lot tougher, considering the 6.4 does regens as well, and the 6.0 didn't.
#68
Parkland,
I know you have a spartan and had a question... The cord that comes with the DD, can you use that to update with if you don't have an SD slot on your computer.. If not the. What's the purpose of the cord? Still need to update and prob gonna need to EGR delete tunes here soon too..
#69
#70
#71
The downside to physically removing it, is that it could be hard or even impossible to sell the truck like that, some places.
#72
Parkland,
#74
#75
RU sure about that 20 psi during regen? First I've heard of that. But what I want to say is about EGRs on the 6.4L. I've had my 6.4L since may of 09 and moved over here from the 7.3L forum at that time. I have pretty much read every post on the 6.4L forum since then. What I have read about is a lot of owners and others being concerned about the EGR coolers, but, I do not recall very many if any actual EGR cooler failures. I did not own a 6L but from what I've heard they made a habit of EGR problems and I think a lor of the concern for the 6.4L coolers stems from the poor reputation of the 6L. Or maybe thay are failing and people are not telling us.
