03 f150 4.6l windsor
Old 03-16-2013, 09:10 PM
jnm0510's Avatar
jnm0510
jnm0510 is offline
i get different answers about the proper torque of the camshaft bearing cap bolts the ones that bolt the cap to the head. torkspec.com says 7.5 ft/lbs.
ALL DATA says 30 ft/lbs then a additional 90 degrees. others say 95 ft/lbs. WOW does anyone know the RIGHT tork. thanks for any input
Old 03-16-2013, 11:59 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
71 to 106 > inch pounds <......... not foot lbs. A big difference.
Good luck.
Old 03-17-2013, 09:59 AM
jnm0510's Avatar
jnm0510
jnm0510 is offline
03 4.6l windsor
thank you bluegrass7 .you said inch pounds, that was also another answer i had gotten there is a big difference between inch pounds and ft pounds your right. i tried 30 ft/lbs like all data said but i broke 3 bolts..opps. o well i will try inch pounds and c what happens thank you.
jwhitetail
06-01-2010 12:04 PM
bfbiker
06-01-2009 10:54 PM
shark1979
05-02-2009 08:39 AM
customkir
1983 - 2012 Ranger & B-Series
10-08-2006 04:33 PM
MisterCMK
Garage & Workshop
09-01-2003 08:49 PM
Quick Reply: 03 f150 4.6l windsor
