Help on coolant lines and another connection
Old 03-16-2013, 08:49 PM
Infinite Monkeys's Avatar
Infinite Monkeys
Infinite Monkeys is offline
Hi,
I'm in the process of putting in a freshly rebuilt 460 in a 1993 F350. When I pulled it I did not take notice of where a couple of thing go.
There are two coolant lines that connect to the cab heater on the fire wall, the other ends go to the intake and one to the water pump. One line has a "T" fitting and I don't know if this "T" one goes to the intake or the water pump.
The other question is there is a quick connect plug coming from near the #2 injector plug. This wire is about 12" long and I can't figure out where this goes.
Thanks for your help.
Old 03-17-2013, 09:11 AM
subford's Avatar
subford
subford is offline
The one with a "T" looks like it goes to the water pump. See image below.
What color are the wire in the plug that you do not know where it goes?
Old 03-17-2013, 09:35 AM
Infinite Monkeys
Hi,
I just realized I forgot to hook up the PCV lines. There's a sensor on there that connects to the plug.
Thanks for the diagram.
AKPOWERSTROKE
05-20-2013 06:46 AM
PaysonPSD
21
05-06-2010 07:05 AM
jkidd_39
10-12-2009 11:37 PM
timmyjay4
1999 to 2016 Super Duty
12-22-2008 04:38 PM
Byrddog
17
02-22-2005 07:46 PM
Quick Reply: Help on coolant lines and another connection
