I need some help with a truck purchase. 96 F250 263k
on
1 Post
I am in the market for a work truck and I have been looking for what seems to be forever. I have found a local truck that has been owned by it's current owner for ten years. It is a 96 F250 reg cab long bed psd with a manual trans. It is a 4x4 with an xlt package, white. The truck drove ok although the steering seems to have just a little play in it. The trans shifted fine, motor ran well, brakes needed a little work, dipstick tube at the oil pan was leaking very bad, fuel leak in the valley, E brake does not work, needs new side mirrors because they are lose and won't stay in place. He is offering the truck to me for $5,800. The truck would suit us well but I am concerned about the miles. I plan on getting it on a lift on Monday to check things out. What do I need to look for and how can I feel good about this buy? Is this a good buy? I don't want to buy this truck and have to rebuild the front end or have it all blow to heck on me when I need it. General thoughts?
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg�s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar � it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
Turbo:
Airbox:
Tranny:
Rear Gear Ratio:
Coolant:
Front end:
Oil:
Aftermarket stuff:
Glow Plugs/Relay:
Injector o-rings:
Leaks and Drips:
VIN number:
on
1 Post
on
1 Post
1996 Ford F-250 XLT 4x4 7.3 Diesel
Here is the link to the truck I am looking at. Thoughts now that you can see it..??
on
1 Post
It just needs a good cleaning. I will know more on Monday evening. I plan to take it to a mechanic and go over it with a fine tooth comb. As far a price goes, if the truck was sound mechanically I think he is asking a fair price. These 7.3's will bring 1-3 over book on any given day of the week. He is spot on KBB's values and he did drop to 5,800. I just can't get over the mileage...ahha
