'89 460 runs like crap when first started, runs fine after 10 seconds.
Hi gang. My '89 recently (2 weeks ago) started running like crap when I first start it up. Normally I start the truck and it idles smoothly at 600-700rpm. Now it starts and stumbles down to 400 or lower, cycles back up to 600, back down to 400ish and then smooths out. That process takes about 10 seconds to complete, after that it runs great as usual.
You can expedite this process by giving it some gas either before or after you turn the key. Then it will go to about 1,000rpm (just depending on where you hold the throttle). If you do that for about 5 seconds it will smooth out from there.
It sounds like it's cammed up like crazy while it's doing this and with either method it smells like gas, like unburnt gas.
It throws these fits almost every time I start it and once it does it in a day it will do it every time, if I let it sit for 5 minutes of 5 hours it's going to do it again.
A couple of hints;
The exhaust manifolds are warped and leak, they tick and let in fresh air. As you know, this throws off the oxy sensor and i'm sure at 24yrs old and about 160k miles has all but clogged the cat up.
I had a problem with the truck dying randomly a couple of months ago. The shop said something was broken inside the dizzy and I had magnetism where I shouldn't. They put a used dizzy off the shop owner's old truck and a new (but not Motorcraft) ignition module on it and it ran fine. Ever since then it will try and stumble a little bit 2-3 times on a cold morning but not right away, most often it starts after I leave my cul de sac but ends before I hit the main road 1/2 mile away.
Once the fit is over she runs great, no other problems with power, hesitation etc.
Any ideas?
-Joe-
A couple of hints;
Any ideas?
-Joe-
A local mechanic told me he thought it might be the Idle Air Controller, what do you think about that?
Thanks!
IDAH0.REDNECK
02-08-2013 10:47 AM
jerd_hambone
16
07-18-2012 11:01 PM
3fourty6
08-13-2007 01:25 PM
