2007 expedition - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 expedition
Old 03-16-2013, 12:42 PM
skygrounder skygrounder is offline
skygrounder is starting off with a positive reputation.
2007 expedition
how do i service the transmission on a 2007 ford expedition eddie bawer?
Old 03-16-2013, 09:38 PM
irishpride1 irishpride1 is offline
irishpride1 is starting off with a positive reputation.
buy the proper filter and fluid. The dealer told me there was a part number split between years in 07 and their filter was 40.00; however, I bought a 14.99 filter from autozone and compared the two and they were the exact same. The fluid was special stuff and I could only locate it at the dealer for 8.99 a qt.
on the passenger side of the trans locate a gold in color bolt, if i remember correctly it was 19mm. it side this lug bolt thing is the fill level dip stick (separate, not the same part) and I read some where that even just doing the drain then fill it was about 8qts. T bought 9 but still can't confirm this as I haven't gotten around to do it.
so locate the thing above, then drain the fluid, then remove the pan, then remove the filter, clean the magnets on the pan. then replace everything. Now for filling it up you can either run a tube down to the fill hole from above (funnel, tube, trans (make since?) and slowly fill it up, or you can use something like a motive transfer pump... once it reads "full" replace the bolt. I was told by the dealer to then start the truck and slowly shift through all gears.. like R.........N...........D..........1 and so on.. Like a 1 to 5 count all the way through and back to Park. Then climb back under the truck and check the trans level. fill as needed to top off.
also a rule of thumb would be to try and make sure the truck says as level as can be so you don't get any false fulls..
good luck.
need to tow 2007 Expedition clcl65 2007 - 2014 Expedition & Navigator 3 12-26-2015 05:09 PM
2007 Expedition Sirius ? thmchristi 2007 - 2014 Expedition & Navigator 3 12-02-2015 07:12 PM
2007 Expedition Cabin Air Fillter becraftj1276 2007 - 2014 Expedition & Navigator 1 01-10-2015 05:43 PM
Need help on a mufler for a 2007 expedition Rickpal28 2007 - 2014 Expedition & Navigator 0 10-28-2014 08:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
