Brewing temp got away from me
Old 07-21-2013, 02:31 PM
Tom D's Avatar
Tom D
Tom D is offline
Smile Brewing temp got away from me
I had preheated the WVO to 145 deg and transferred it to my mix tank. I usually lose a few degrees in the transfer. It was about 137 deg prior to adding KOH/meth so I turned on external heater and added chemicals. I shut off external heat at 140 deg. The temp continued to climb to 149.7 deg at which time it finally peaked only after forcing the temp to stop by placing heavy metal heat sinks in the mix. I was getting nervous. I vaguely remember the flash temp for the methanol to be 148 deg (I may be wrong). This is the first time I could not control the temp. Do you think it was a chemical reaction that caused this? I did add the chemicals faster than usual. The batch came out fine although I probably flashed off quite a bit of methanol. It was over temp for approx 45 min.
Wishing all my "brewing brothers" the best and thank you for your continued support of our forum
Tom D
Old 07-22-2013, 07:31 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Howdy Tom! I had it happen once and a small "cloud" of vaporized Methanol "floated" above the mix. Scared the crap out of me, but turned out OK........
Old 07-22-2013, 03:31 PM
Tom D's Avatar
Tom D
Tom D is offline
Hey Don
Great to see you are still keeping an eye on me and keeping me out of trouble
I certainly didn't want any kind of fire. That's my worst "F" word nightmare
Thanks as usual for the help all these times
Tom
Old 07-24-2013, 09:29 AM
flainn's Avatar
flainn
flainn is offline
Mixing KOH and methanol causes a remarkably exothermic reaction. I found that mixing them in a 5-lb cubie was dangerous, especially when I was in a hurry to get them mixed and added to a batch of hot WVO. I never popped the safety valve on my appleseed reactor, but I did have a fountain of methoxide one time because I added too much KOH too quickly to several gallons of methanol. Scared the hell out of me.
I'm betting that's what happened here ... gotta let the methoxide cool off before adding it to your WVO, or you'll see your temperatures climb. As long as you've got a pressure relief valve on your reactor, though, you should be all right.
Old 07-25-2013, 06:37 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
I've almost had the same thing happen, learned to shut off the heat around 120 - 125. Temp usually continues to climb as reaction takes place.
Good to see everyone's still active, thought this site would get busier as Diesel prices went back up. Running $3.85 here. Stay safe!
ttttmaxx
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-15-2011 10:26 AM
dyoungen
09-25-2010 02:35 PM
BostonX73
04-25-2010 11:08 PM
HappyJack
Kansas Chapter
01-25-2008 08:26 PM
RCsanjose
07-23-2003 11:20 AM
Quick Reply: Brewing temp got away from me
