1990 Ford F250 Tilt Steering issue
Old 03-15-2013, 03:29 PM
tmdmjones's Avatar
tmdmjones
tmdmjones is offline
Greeting all,
I am new to this site. I recently bought a 1990Ford F250 4X4 with tilt wheel. The ignition lock actuator was broken off insidethe column. I took it apart and replaced the broken actuator but cannot get thetilt steering to release. It didn’t work before I bought the truck either. Anyidea how the tilt wheel releases so I can use the tilt feature? Does it releasewith the small lever under the column? Any help would be much appreciated,thanks
Old 03-15-2013, 04:45 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
To tilt the steering wheel, you pull on the small lever (looks like a smaller turn lever) or on some models you push forward on the turn signal lever.
Welcome to FTE
Old 03-15-2013, 05:07 PM
tmdmjones's Avatar
tmdmjones
Ok, so it is the turn signal lever, and it now works. I would have never assumed that the tilt was from the turn signal lever. Thanks for the info.
n4ynu1010
09-18-2012 01:06 AM
FatBrian
13
08-12-2007 05:22 PM
ford351c
13
08-27-2004 11:07 PM
Harlyred1
13
02-21-2003 02:27 PM
IES
05-03-2002 07:36 PM
Quick Reply: 1990 Ford F250 Tilt Steering issue
