1958 hood badge stud repair ? - Ford Truck Enthusiasts Forums
Old 03-15-2013, 03:29 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
thundersnow70 is starting off with a positive reputation.
so i picked up a 58 front hood badge and the upper mount got broken off in the battle. and when i say battle, it was 50 minutes to get it off and the only reason the battle ended was because it did finally break. now i am wondering how to fix it. has anyone ever repaired one or know of a easy fix. it broke off flush at the base and i still have the stud and nut. thanks in advance!
Old 03-15-2013, 09:16 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
I have never tried to repair pot-metal, which I believe the emblem is made of. There may be some technique unknown to me, but if it were me I might consider drilling and tapping the badge, then epoxying in a small diameter threaded stud with a nut. The emblem may be to thin for this though. And you would of course have to enlarge the mounting hole.
If it were me, I would just locate a different one. Good luck, Steve.
Old 03-16-2013, 12:37 AM
thanks Steve. the pot metal stem that broke is pretty small so drilling out and retaping may not work. i doubt there will be enough material left to re-tap. im gonna try the pin and epoxy or jb weld first. if that fails it will get passed on with a bad upper post and the next owner can do as he will. thanks again
Old 03-16-2013, 12:45 AM
ibuzzard's Avatar
Nice of you to pass it on to someone in need. As stated, they could always just use 2-sided tape.
Old 03-16-2013, 12:41 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
I guess it would depend on how hard you have to slam the hood!
Old 03-22-2013, 02:30 AM
Tumblindyce's Avatar
Tumblindyce Tumblindyce is offline
Tumblindyce is starting off with a positive reputation.
I wonder if you could set the head of a small bolt, like a 10-32, in epoxy on the back of the emblem in place of the stud.
broken hood badge stud thundersnow70 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 03-17-2013 10:53 AM
1961 ford hood badge 63flareside Ford Truck Parts for Sale 4 01-06-2013 08:47 PM
Glue for Badges DarkWolf40 Paint & Bodywork 2 05-26-2008 06:15 PM
Went to battle to remove a fender jack71 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 01-25-2006 03:36 PM
It coulda been worse! NoMo Modular V10 (6.8l) 23 12-26-2005 03:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
