My 78 F250 Resto so far - Ford Truck Enthusiasts Forums
Old 03-15-2013, 12:53 AM
Tom French Tom French is offline
Tom French is starting off with a positive reputation.
Here's a bunch of pictures of my Ferd, it's a little more together right now, at least getting there, you guys know how it is
Hurricane prep...
much better bed
the plastic insert broke
made a aluminum one
fiber glassed that sucker
everything that could have been shot in this axle was...
Old 03-15-2013, 07:40 AM
'78F250351m's Avatar
'78F250351m '78F250351m is offline
'78F250351m is gaining momentum as a positive member of FTE.
Nice. I'm in the same process myself. I didn't take my '78 250 apart as much as you, that's a lot of hours you've put in. I like the last pic....luckily we had a pavilion added onto our barn so i've had the luxury of parking it under there where its out of the weather a lot more. Good luck!
Old 03-15-2013, 09:31 AM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.
lookin good!
Old 03-15-2013, 10:15 AM
Laser_Target Laser_Target is offline
Laser_Target is starting off with a positive reputation.
Nice looking project. My box floor looks just like yours did, I'll be rebuilding/ welding in a flat floor in mine when the snow finally leaves
Old 03-15-2013, 10:52 AM
Filthy Beast's Avatar
Filthy Beast Filthy Beast is offline
Filthy Beast has a good reputation on FTE.Filthy Beast has a good reputation on FTE.
Lookin' good! Lot of time in that puppy...Looks like a 4" or better body lift there?
A bit squirrely around corners?
Old 03-15-2013, 02:00 PM
yeah, got quite a bit of time in the Ferd, I got a set of 37's, they are on the back now, I just painted the inside of my front clip, I have to paint my front axle, press in new drive shaft u-joints, bend new front brake lines, and put my 73-77 grille on the truck and it'll be good to go. Just have to bolt up the front clip and bed. Filthy Beast-It's a 3 inch body lift on top of the 4inch suspension, definitely gonna be interesting around corners haha
Old 03-15-2013, 06:54 PM
More pics from this week:
Old 03-15-2013, 08:04 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
Who did the rearend swap? That rearend isnt stock. Looks like a semi float 60. Weaker than the stock fullfloat 60.
Old 03-15-2013, 08:18 PM
YZ250rider YZ250rider is offline
YZ250rider is starting off with a positive reputation.
Lookin Nice!
Old 03-15-2013, 08:27 PM
chris989 chris989 is offline
chris989 is starting off with a positive reputation.
Tomfrench,
What spring did you put on the rear? I was noticing the shackle angle on the passenger side. do you feel the springs are a little short? or do you think it will straighten up with more weight added?
Thank you,
Chris
Old 03-15-2013, 08:57 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Nice thread !! on your pic of the transfer case are the brackets and rubber assembled correctly? Oh I see you just have it sitting there, no crossmember or frame to transfer case bracket .. Never mind Keep up the good work
Old 03-16-2013, 12:10 AM
Thanks for all the feedback guys, hopefully i'll be firing it up next week for the first time in a while
Crazyredneck- I didnt swap out the rear axle, what's there was there when i got it. I guess i find out how heavy duty it is when I take it in the woods!
Chris989- I also didn't pick those springs out, i just cleaned up the ones that were on there. They sat at a good level before i tore the truck apart
Old 03-16-2013, 12:30 AM
75Three90's Avatar
75Three90 75Three90 is offline
75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.
Nice trUck
Old 04-14-2013, 08:23 PM
Little more progress this weekend. Still have some stuff to figure out with the wiring. I'm trying to get everything hooked up, it was all pretty rigged when i got it as was everything else on it.
Old 04-14-2013, 09:40 PM
1975MudRat's Avatar
1975MudRat 1975MudRat is offline
1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.
Look good!! But, I have a question, its a F-250 but the front of the frame has the F-150 "Bull horns" for the front bumper, did you cut some off on a F-150 and put them on your truck?
forgot where the wires go on my altenator...oops! Tom French 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-11-2013 03:28 PM
DIY Headlight Harley Mod completed...pictures inside Gage2502 1999 to 2016 Super Duty 9 08-24-2012 07:16 PM
Modified factory steps, Dechromed and Painted, LEDs reinstalled Gage2502 1999 to 2016 Super Duty 4 07-30-2012 02:04 PM
Anything I can do to save my cab mredington Paint & Bodywork 2 03-29-2012 02:54 AM
Saginaw Drop pitman arm questions--with pics mjshagnasty 1973 - 1979 F-100 & Larger F-Series Trucks 32 08-08-2011 08:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
