Front Leaf Springs! Pro Comp or X Codes - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-14-2013, 04:50 PM
ronjon95's Avatar
ronjon95 ronjon95 is offline
ronjon95 is gaining momentum as a positive member of FTE.
Everything I have been reading is making my head spin! Some one should have the answer for me. I have a 2000 F-350 4X4 with what I was told by the previous owner 2.5" leveling Kit which is the extra springs under the factory springs. I believe that my factory front springs are sprung. I would really like to keep a level ride due to having larger tires. So what would be a better route to keep the height and get a little more stiffness to help prolong life of the springs.
Thanks
Old 03-14-2013, 06:15 PM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
I preach this because I had great luck with it. Find a local truck spring shop and have them build you a set of springs. It was cheaper in the long run for me.
Old 03-14-2013, 08:12 PM
ronjon95's Avatar
Thanks! I found one that is highly recommended. I was wondering if anyone had a couple of pictures still on the truck with the old saggy stock springs and then a set of new perky ones? LOL Perky!
Old 03-14-2013, 09:00 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
subscribing...
I'll update this thread when done. Buddy's goin thru same thing, and we're gonna role my father up to get a set made..(level ride). He's the accountant for Deaver..
Old 03-21-2013, 01:19 PM
ronjon95's Avatar
I have spoke with the local spring shop. He has estimated me at $500.00 for a new set of front springs. For him to install the is a additional $400 to $500. I also called Tousley Ford and shipped to my door and taxes approx. $400.00 for X codes this is with out new U bolts and nuts and washers.
I think I will be installing these myself!!
My confusion of getting the X codes how much of a lift would I see? I currently Have V codes and a 2.5" leveling kit. With my wheels turned completely one way I have about .5" clearance between the wheel well and tire. If I took off the leveling kit and just put the X codes on how much of a lift would that give me over stock height?
Thanks guys!!!
Old 03-22-2013, 09:22 AM
ronjon95's Avatar
Found the Leveling Kit
This is the leveling kit that I believe is on my truck! So I could just replace the V code springs that came on the truck factory. Or if like I was asking in the above post Would the X codes give me a 2" lift?
Our standard 2.5 inch Ford leveling kit includes 2 front progressive spring packs with teflon pads to reduce friction, Adjustable Track Bar, 2 center pin bolts, 4 U-bolts with hardware and detailed step by step instructions. This Ford leveling kit will allow you to run 35x12.5 tires on a 10 inch wheel with occasional minor rubbing. To avoid any tire rubbing, run 33 inch tires.
Last edited by ronjon95; 03-22-2013 at 09:23 AM. Reason: Forgot to add information
Old 03-22-2013, 01:17 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
I got 1.5" lift on my truck going from V to X codes.
Old 03-22-2013, 04:45 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
I am buying X codes for my truck from Titus will ford parts online. A few dollars more than tousley ford, but the shipping for is less than half. About $330 to my door for the pair of x codes.
i was debating doing procomps or X codes, but i think the OEM springs will hold up better to the weight of a diesel. If i had my old gasser, id put procomps on
79 4x4 - level truck with front springs. gfburke 1973 - 1979 F-100 & Larger F-Series Trucks 23 05-20-2015 08:32 AM
Lift Kit Help LCrowe2012 1999 to 2016 Super Duty 4 02-25-2014 02:59 AM
U code front springs JIMBOEX Excursion - King of SUVs 5 08-21-2010 02:57 AM
'88 F-150 Coil springs? Airslot Brakes, Steering, Suspension, Tires, & Wheels 4 04-06-2005 07:58 AM
Will the X springs level my 04 F-250 diesel? drfbuster 1999 to 2016 Super Duty 13 10-01-2004 05:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
