Starter removed, where did this gunk come from??
Old 03-21-2013, 10:47 PM
milman's Avatar
milman
milman is offline
So I removed the starter this evening from my '99 to have it tested. I didn't clean around the starter before beginning removal, so there was plenty of gunk and grit buildup falling all over the place. That's no problem, but what I found inside worries me:
Any ideas what that is, where it could have come from, and if I should be worried? It's even a bit colorful, has a couple of blue flecks or spots in there. Overall looks like a mixture of sand, grease, and probably a few other things.
Old 03-21-2013, 11:02 PM
DND58's Avatar
DND58
DND58 is offline
I think the valley drain may be a pretty good path to near the starter. Just saying. Do you have, or ever had any leak issues up top?
Old 03-21-2013, 11:15 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
looks similar to gunk from long term coolant leak.
Old 03-21-2013, 11:43 PM
milman's Avatar
milman
milman is offline
I am pretty confident I had oil leaking from the turbo pedestal before I deleted the EBPV, but I haven't noticed anything in the valley since then (late last year). I could see why that would leave gunk on the outside of the starter, but how would that get inside the receiving end of the housing?
Same question, where would that bring gunk into the starter housing? Probably calling that by the wrong name. You can see the mating surfaces are oily but grime-free, but there's no space for the grit to get inside through that joint. As far as I can tell, I haven't leaked coolant since water pump replacement early last year.
Old 03-21-2013, 11:59 PM
tappit01's Avatar
tappit01
tappit01 is offline
is the inspection plate tightly In place at the front of the trans.
Old 03-22-2013, 12:26 AM
milman's Avatar
milman
milman is offline
I'll take a closer look at everything in daylight to find out.
Old 03-22-2013, 07:47 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Manual trans or automatic?
Looks like normal grime to me especially in a diesel.
Old 03-22-2013, 12:30 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
What he says, looks normal to me especially if you've ever had any kind of leak up top. Think about it, anything that runs down the drain hole in the valley is going right down the back of the block with the flywheel/flexplate slinging everything around. If you really want to see some crud take the cover plate off of the flywheel/flexplate lol
Daxy
06-09-2018 02:29 PM
PStruwing
04-09-2012 10:59 AM
joe f350
11-15-2010 10:05 AM
1974F100
01-24-2007 04:34 PM
Thibor91XLT
1978 - 1996 Big Bronco
08-02-2003 02:11 PM
Quick Reply: Starter removed, where did this gunk come from??
