1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
BrakeSmart to Ford Integrated controller
Old 03-14-2013, 02:34 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
Has anyone gone from a BrakeSmart or Max Brake to a Ford controller and how would you compare the two. I can't decide if I want to keep my BrakeSmart in case I don't like the integrated one in the truck I have on order or just sell it.
Denny
Old 03-14-2013, 10:20 PM
cschannuth's Avatar
cschannuth
cschannuth is offline
I've nevered found any aftermarket brake controller that compares to the integrated controller. The integrated unit applies the trailer brakes seamlessly. You will not know a trailer is behind you. You will like it.
Old 03-15-2013, 06:00 AM
sammy77's Avatar
sammy77
sammy77 is offline
The only aftermarket controller I would buy is a Prodigy.
Old 03-15-2013, 08:15 AM
RPM371's Avatar
RPM371
RPM371 is offline
I pull a heavy trailer quite a bit and love my integrated controller.
Old 03-15-2013, 08:16 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
The BrakeSmart and Max Brake also work off the tucks brake pressure (master cylinder) like the Ford integrated to give you a seamless braking but they are not cheap controllers, I just wanted to know if the Fords worked as good before I sell my BrakeSmart.
Sammy77 you should try a true propositional set and forget controller like BrakeSmart or Max Brake you will never go back to a Prodigy.
Denny
Old 03-15-2013, 06:28 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
the brake Smart and Max Brake don't pulse the trailer brakes when the ABS kicks in, do they?
Old 03-15-2013, 06:39 PM
senix's Avatar
senix
senix is offline
Received 1,406 Likes on 1,002 Posts
I have had a couple of prodigy's. I would never go back to them after having the integrated one.
Old 03-15-2013, 06:46 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
No they don't
Denny
Old 03-16-2013, 06:59 AM
sammy77's Avatar
sammy77
sammy77 is offline
Denny
I hear that all the time from my RV buddies. I've never tried a true propositional or had an integrated one on my truck. I mostly tow enclosed type trailers no more than 30ft these days. Next truck I get will definitely have the integrated unit. Heck, can you even get a truck without one in it already these days?
67xr7kat
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-16-2020 09:02 PM
Ben Albert
03-02-2013 05:18 PM
ssjrsw
Ford Truck Parts for Sale
02-08-2012 04:48 PM
kell104
01-11-2009 05:06 AM
igotjam
16
11-09-2007 07:11 PM
Quick Reply: BrakeSmart to Ford Integrated controller
