67 metal bezel,can it be install on a 68 gauge cluster? - Ford Truck Enthusiasts Forums
Old 03-14-2013, 12:04 PM
Bad 674x4 Bad 674x4 is offline
Bad 674x4 is starting off with a positive reputation.
I have the chance to buy a 67 metal bezel. In my 67 ford someone put a 68 plastic bezel with gauges. I would like to use the 67 metal bezel,and use the 68 gauge cluster. Can i do this?
Old 03-14-2013, 12:34 PM
Gembone's Avatar
Gembone Gembone is offline
Gembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to behold
the identification on fordification shows the cluster 67-69 being the same(at least from the back).
Linky to article
I am sure someone with more knowledge can verify or contradict this.
Was just what I found.
Old 03-14-2013, 01:08 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Gembone View Post
the identification on fordification shows the cluster 67-69 being the same (at least from the back).
Clueless Fordification.com has the 1964/72 Ford Truck Parts Catalog on their website. Someone over there should open their peepers and look up the following:
C7TZ-10848-B .. Instrument Cluster Back-Use with Oil/Amp Gauges = 1967 F100/350 ONLY.
C7TZ-10848-C .. Instrument Cluster Back-Use with Oil/Amp Warning Lamps = 1967 F100/350 ONLY.
C8TZ-10848-A .. Instrument Cluster Back-Use with Oil/Amp Gauges = 1968/69 F100/350 ONLY.
C8TZ-10848-B .. Instrument Cluster Back-Use with Oil/Amp Warning Lamps = 1968/69 F100/350 ONLY.
1970/72 F100/350's have printed circuit boards. 1970 cluster backs/printed circuit boards are one year only, 1971/72 is the same.
Old 03-16-2013, 09:32 AM
19704X4F250's Avatar
19704X4F250 19704X4F250 is offline
19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all
Yes, the '67 bezel will mate with the '68 cluster. The plastic bezel in my '70 was faded and the mating points were split. The '70 gauge cluster was hard to see with the '70 bezel while driving and the '67 bezel fixed all that for me.
Alloy/steel dash panel bezels shaker666 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-06-2015 07:08 PM
1967 metal bezel/ 1968 instrument cluster Bad 674x4 1967 - 1972 F-100 & Larger F-Series Trucks 0 04-05-2013 10:55 PM
F500 instrument cluster Area351 1967 - 1972 F-100 & Larger F-Series Trucks 30 03-30-2013 09:32 AM
67 68 69 Aluminum Headlight Bezels gangstakr WTB - Parts & other 3 10-20-2012 12:53 PM
Turn signal **Indicators** Color difference? ceetwarrior 1967 - 1972 F-100 & Larger F-Series Trucks 20 12-23-2003 02:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
