1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Heavy Duty Alternator
Old 03-13-2013, 11:33 PM
STEVES68NOVA's Avatar
STEVES68NOVA
STEVES68NOVA is offline
How many amps/volts is this alternator? Can you replace it with a larger one without causing problems. My alternator light is on and I believe it to be the voltage regulator as it is putting out 13+ volts. The regulator is part of the alternator isn't it?
Also, on my drivers door almost to the bottom is a light which lights up when you open the door. Is the cover to this light the same on all doors from 1999 to 2006? Or maybe later.
Also the arm rest on my captain chair drivers side just falls down. It is supposed to allow you to put your arm on it, but it does not. I can live without it but would be nice to have it fixed.
Old 03-14-2013, 04:21 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
13.6 volts +/- is normal output for an alternator. The regulator is built in.
Before you replace the alternator, get it tested.
Camper Special Gene
01-29-2015 07:50 PM
Hansolo99
05-19-2014 08:59 AM
sciondude09
03-15-2009 05:59 AM
mike
11-09-1999 02:25 AM
Ron Lawson
08-21-1999 08:47 PM
Quick Reply: Heavy Duty Alternator
