Vacuum leak - Ford Truck Enthusiasts Forums
Vacuum leak
Old 03-13-2013, 09:26 PM
SiscoKid SiscoKid is offline
SiscoKid is starting off with a positive reputation.
Vacuum leak
My 89 f-150 4.9 300 6 cyl has a vacum leak. From the gas tank, to under the hood from along the frame rail, the vacum line is missing. And i recently discovered a line running of the transmission that has. been plugged off about 5 inches from the tranny. Dont know where it goes I would love to get this fixed, so my truck stops running like crap. Anyone have a diagram for dummies that could help me reconfigure the vacuum line setup? Also, there is a small diameter tube running from the engine to the exhaust, just before the cat. Anyone know what that is and the purpose it serves? Whatever it is, has rotted off and makes for a horrible exhaust leak, and makes my truck sputter and **** like crazy. And quite possibly the best way to fix it? A combination of vacuum line leak and exhaust failure is driving me nuts! Please help...
Old 03-13-2013, 09:34 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like the vacuum line the goes on the back of a C6 transmission (TP vacuum motor).
Old 03-13-2013, 09:38 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Can't help you on the vac diagram.
The tube that hooks into your exhaust is part of the air pump system. I don't know the details of how it works, but at given times the valve it hooks into will open and the air pump will shoot extra air into the exhaust.
The way I fixed mine was I cut a chunk of 3/4" electrical conduit and welded it onto the tube. It's not 100% leak free by any means, but it's certainly better than it was.
Old 03-13-2013, 09:50 PM
Quote:
Soo, from the back of the trans to a vaccum motor?
Old 03-13-2013, 09:53 PM
Nice fix idea on the air pump system... Did your truck run badly when that tube was separated from the exhaust??
Old 03-13-2013, 09:56 PM
subford's Avatar
Quote:
No the vacuum motor is screwed into the back of the C6 Transmission and the vacuum line runs from there to the vacuum source on the engine.
This vacuum line tells the Transmission the throttle position or the load on the engine.
Old 03-13-2013, 10:07 PM
Thanks, that helps alot. Would you know where to find locality of the vacuum source at the engine from the trans?
Old 03-14-2013, 09:20 AM
subford's Avatar
It hooks to the Engine Vacuum Distribution Block.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
93 f150 4.9 vacum leak?? 300-six 1987 - 1996 F150 & Larger F-Series Trucks 6 12-22-2012 06:58 PM
AC Vacum Leak? dcara 1999 - 2003 7.3L Power Stroke Diesel 14 08-20-2012 01:51 PM
Vacuum line diagrams? 66gpw Ford Inline Six, 200, 250, 4.9L / 300 5 10-24-2011 10:37 PM
Ping/knock 351M jopey 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 19 08-26-2001 02:22 AM
Tags
300 6cyl, 89 f-150, exhaust, vacuum leak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
