Dual carb on a 223? - Ford Truck Enthusiasts Forums
Dual carb on a 223?
Old 03-13-2013, 05:38 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Dual carb on a 223?
Anybody got dual carb set up on a 223? What intake did you use? What carbs? Does it run better? Faster? Any info would be great.
Old 03-13-2013, 09:12 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
If I'm not mistaken, Fenton, Offenhauser, or both, made a dual carb intake. I am certain that you will pay dearly if you can locate one.
You might want to ask around in the Inline Six Forum on FTE, someone can tell you the options.
That is a really nice looking truck. Good luck, Steve.
Old 03-13-2013, 09:43 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
My brother ran a 3 carb set up on a couple of GM 6 cyl's in the 70's and 80's . Stromberg set ups I think . They were wicked . He won as much with them as with his Olds. set ups . I know what you want is out there , Offey , and others . Look at swap meets . Go meet Old Ford groups . Many are willing to give info if they don't have ! They may turn you on to something .
Old 03-14-2013, 01:40 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
Have a Look in "My Gallery" & you'll find several Pix of my Offenhauser. I've also a Fenton waiting for the next iteration as well.
Quote:
Old 03-14-2013, 02:35 PM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Here is a link for you. High $$$$$
Clifford Performance :: Make 6 = 8
Old 03-14-2013, 07:17 PM
Damifiknow's Avatar
Do they run better thsan the single? Any problems? What carbs? Duel 1904's? I've seen on ebay a duel set up for 300 bucks. Worth it?
Old 03-14-2013, 07:18 PM
Damifiknow's Avatar
Quote:
Thanks man.
Old 03-14-2013, 10:55 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Faster with dual carbs? I would imagine. Better? Not always.i I have a lot of experience running flathead V8s as a daily driver. Nothing beats a stock flathead with a single stock carb for smooth idle, easy and fast starting and general tractability driving in most real life situations. I'm guessing a 223 would run better with its original carb. At 60 years old in May, I'm willing to admit I've been wrong before, and I may be wrong this time. There's an old, old saying in hot rodding. "Nothing beats cubic inches". Of course who am I to say? I replaced the 223 in my '59 with a 210 cu in diesel. But then again, I'm no hot rodder. Duh.
Old 03-15-2013, 12:51 AM
Yes, yes they do run better. W/ Duell 1904 Holleys, you've no starvation problems on the 1st & 6th cylinders that you do w/ a Centered Single 1904 Holley.
Just the usual one has when you run Duells on any thing.
That's a steal, I'd jump on it if I were you, just the Intake usually goes for $300.00, then you add $150.00 a piece for the Carbs.
Old 03-15-2013, 08:07 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
It will run better do to better fuel distribution. I had a Offenhauser with 1904's but making the linkage was a nightmare so I traded it.
Old 03-15-2013, 08:35 PM
Damifiknow's Avatar
the ebay guy says it should fit a 1960 223 motor. His ad says 57-58. Is there a difference in the 60 vs the 57-58. Same same?
Old 03-16-2013, 12:44 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
223 manifolds should have the same footprint.
Old 03-17-2013, 02:20 AM
Same, Offenhauser sells the linkage if not currently present.
Old 03-17-2013, 11:33 AM
GB SISSON's Avatar
The 'fuel starved ends' makes sense to me. Maybe one of the reasons fuel injection is so common today. Damifiknow anything about hot rods anyhow.
Old 03-17-2013, 02:56 PM
spurredon's Avatar
Quote:
I am pretty sure I know less than you!
Offy dual carb intake on a ford 223 Daddyo's garage 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-24-2016 10:21 PM
intake for 223 wills 64 1961 - 1966 F-100 & Larger F-Series Trucks 6 06-26-2015 04:50 AM
dual exhaust on 223 wndsofchng06 1961 - 1966 F-100 & Larger F-Series Trucks 7 06-03-2015 10:01 PM
223 valve lash 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 1 04-27-2015 07:09 PM
Clifford header intake combo experience pholmes350 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-01-2014 04:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
