2011 6.2L multiple misfire
Hello,
Looking for any ideas.. Working on 2011 F250 w/6.2L.. Came in missing on 6 cylinders 1-4 ,7 & 8... Spark & Injector pulse good, compression good on all cylinders except 5 (one that is hitting) which is down 20% by scanner and about 30psi checking with guage..Spark plugs were not soaked.. Tried injectors no change.. Vacuum guage fluctuates rapidly.. Codes were misfire related.. Pulling hairs here.. Any suggestions would be greatly appreciated..
MOTOR Magazine Article | MOTOR Information Systems
If vacuum is steady at idle but lower than normal, the ignition or valve timing may be retarded. Low compression, an intake leak or tight valves also can cause low vacuum at idle.
If the vacuum reading fluctuates within the normal range-the gauge needle bounces around a lot-uneven compression (broken rings or leaking valves or head gasket in one or two cylinders) is a likely culprit. An uneven air/fuel mix, erratic ignition timing, a misfire, misadjusted valves or a manifold leak near one or two cylinders also are possible causes.
If vacuum drops intermittently at idle, one or more valves may be sticking open or dragging. Higher-than-normal vacuum at idle is a common clue to overly advanced ignition timing, while low vacuum can indicate retarded timing.
Low vacuum also can be an immediate clue to a plugged exhaust. To check further, run the engine at about 2500 rpm for about 15 seconds. If vacuum drops during this period and does not increase when you close the throttle, you're almost certainly looking at a restricted exhaust.
Hello,
If number five is the only one without a misfire than it has not had its fuel supply taken away yet either, working harder to cover the dead weight of other cylinders, diluting the rings a bit prolly. I would look at the fuel very close. Sometimes its hard to smell out the diesel/gas depending on the mix if thats what happened. Sometimes you just get a skanky batch of fuel that smells right and looks right but the volatility is off. These newer engines these days don't tolerate questionable fuel like the old days. Emptying the tank and adding known good fuel at the very least will eliminate variables for you at this point going forward.
Truck was filled at very busy station.. Fuel volatility has to be fair enough if can run on two cyl's , literally will run on 5 & 6 with all other coils unpluged.. Water in fuel possible and too easy not to check for.. Again though, replaced all injectors with no change.. Do believe have an effective vacuum leak in possible valve problem on 5... Having a problem believeing this is killing 6 cyl's though.. My thinking is corrupt software or bad sensor input also.. Keep in mind same cylinders are being affected consistantly.. Many of thoughts I have had and some of the suggestions should be affecting all cylinders randomly.. Thanks for the imput, will check a few things you all have suggested.. Will be later this evening though..
What ended up being the issue on this truck. My dads truck is doing the exact same thing.
Hello,
UZI-SUICIDE
115
08-05-2013 08:00 AM
pit_of_pity
11-10-2010 10:33 PM
derherr65
08-27-2006 08:23 PM
