hydro boost conversion on 1990 f350
Old 03-13-2013, 12:09 PM
fordman400's Avatar
fordman400
fordman400 is offline
Im looking to do a hydroboost conversion on my 1990 f350 long bed crew cab dually diesel. I was woundering if a 99 and up F or E series bosster would work? I ask because I could a hydrobooster, master cylinder, hoses and pump from an 08 E350 for next to nothing. My budy wrecked his van. Any input would be highly welcome.
Old 03-13-2013, 12:13 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
nope but list it on ebay and take the $ to put towards the parts you need.you'll probably end up $ ahead still.
https://www.ford-trucks.com/forums/1...st-brakes.html
fyi;
vac brakes are easier to press/more driver comfort than hydro.the power doesn't compare,but if you don't need the hydro,keep your vac is my advice.
there are pro's and con's to every modification,and sadly most people don't inform others of them while making their suggestions about upgrades.swapping to hydro with a stock, light, pickup setup with stock tires or slightly larger that's just driven around empty most of the time is an unworthy candidate for the swap imho.for my heavy hauler,it was a night and day safety upgrade.
Old 03-13-2013, 01:07 PM
fordman400's Avatar
fordman400
Thanks for the info. I use my truck mostly for work purposes towing and hauling. My brakes work good with the vac system. Just looking for something better had vac pump go out lot much fun stopping then. Thanks again.
crystalhand
26
06-30-2015 07:04 AM
AMARON
1999 to 2016 Super Duty
11-12-2014 06:06 AM
F-250 restorer
08-02-2013 03:07 AM
pauls painting
03-11-2008 08:18 PM
ogredorf
1978 - 1996 Big Bronco
12-11-2002 09:26 PM
Quick Reply: hydro boost conversion on 1990 f350
