what wt oil for tran and rear end
Old 03-13-2013, 12:09 PM
1950F2's Avatar
1950F2
1950F2 is offline
I'm working on a 1950 F2 that has been sitting 43 years in a barn.
What gear oil is used for trans(4 speed crash box) and stock rear end??
Would it be a good idea to warm up the trans and rear end to get the old oil to "flow" better?? heat gun/torch it a little??
When I took oil pan off it was like coal tar inside!!
also. how much in ea.
thanks!!
Old 03-13-2013, 12:37 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
Typically you will be good with a 85-90 wt gear oil. Obviously it will flow better warm but unless something real nasty comes out just letting it drain a little while before refilling and you should be fine.
Old 03-13-2013, 01:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
You are supposed to use a GL-3 gear oil, which isn't usually available except at farm /fleet stores. GL-5, the most common gear oil nowadays, can attack the copper in the trans (synchro blocker rings). There are exceptions, see below
Old 03-13-2013, 07:17 PM
kenjh's Avatar
kenjh
kenjh is offline
I have flushed out my trany transfer box and both axles with 90 weight ..and after a good run and warmed up changed it all out for amsoil synthetic a lot quieter and seems to run cooler ..at least no gear oil smells now but I agree pull th eplug and let it drain for the night ..don't heat it with a torch ..I set fire to mine doing that ..yah I'm an idiot ..
doublecanister
05-16-2012 12:13 PM
sawyersvintage
08-12-2011 07:19 PM
68 ranger
10-14-2008 09:48 AM
wycowboy
11-19-2007 12:09 AM
MTurner2003
18
10-27-2005 09:07 PM
Quick Reply: what wt oil for tran and rear end
