what wt oil for tran and rear end - Ford Truck Enthusiasts Forums
Old 03-13-2013, 01:09 PM
1950F2 1950F2 is offline
1950F2 is starting off with a positive reputation.
I'm working on a 1950 F2 that has been sitting 43 years in a barn.
What gear oil is used for trans(4 speed crash box) and stock rear end??
Would it be a good idea to warm up the trans and rear end to get the old oil to "flow" better?? heat gun/torch it a little??
When I took oil pan off it was like coal tar inside!!
also. how much in ea.
thanks!!
Old 03-13-2013, 01:37 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Typically you will be good with a 85-90 wt gear oil. Obviously it will flow better warm but unless something real nasty comes out just letting it drain a little while before refilling and you should be fine.
Old 03-13-2013, 02:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
You are supposed to use a GL-3 gear oil, which isn't usually available except at farm /fleet stores. GL-5, the most common gear oil nowadays, can attack the copper in the trans (synchro blocker rings). There are exceptions, see below
Old 03-13-2013, 08:17 PM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
I have flushed out my trany transfer box and both axles with 90 weight ..and after a good run and warmed up changed it all out for amsoil synthetic a lot quieter and seems to run cooler ..at least no gear oil smells now but I agree pull th eplug and let it drain for the night ..don't heat it with a torch ..I set fire to mine doing that ..yah I'm an idiot ..
1950 F2 4 speed 1950F2 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-11-2013 07:21 PM
1950-1950 Panel Trucks Skirouled! 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-15-2011 05:16 PM
F5 to F6 Transmission compatablity JMS50F5COE 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-20-2010 04:19 AM
what's the stock rear end of a 1950 F1? Vee 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-14-2006 08:59 PM
1950 F-1 rear axle swaps cot 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-12-2001 12:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
