TSB 13-3-8 2011-2013 F-250 Super Duty 4x4 - Rear Of Vehicle Sits Lower Than Expected Under Light Loa
Found this web site on one of the forums. It's updated daily but they do roll off so need to check frequently.
http://www.vrep.fordtechservice.deal...adcast=ON&from=
Not sure what your concern is. F350 uses the 4" blocks. Only thing they dont seem to be adding is the overload leaf as well. Airbags are probably a better option, but Ford won't do that. Good luck getting this TSB done under warranty. Looks like a long list of expensive parts, and labor.
on
that tsb is foolishness.it's like ford doesn't even think how people use trucks.there is no need to jack the truck up with a taller block.the only thing that changes is the appearance in how much the springs are sagging.not how much they really are.the truck's sitting higher,therefore it'll just look like it's not sagging as bad on the load.they're trying to pull a jedi mind trick.
unfortunately,it's you lifting your items up into the bed,not those fools at the desk who wrote that foolishness.
for those that want to really address the issue,keep your ride height low for easier loading of your beds and decent fuel economy.no need to swap the other junk either.
simply take your truck in if you don't want to do it yourself and ask for exactly;
1.one more full length main leaf.
2.a double aux pack (custom bent if need be) to set slightly below the aux brackets so it doesn't hit over bumps,but not too less of an arch that they don't start holding her up too late when adding weight.then you'll have your cake and eat it too.possibly address the 45mph hop many experience at the same time.
