Anybody have a 240 cid Crankshaft?
Well after a couple of months of having the engine apart and to the machine shop, I find I'm in sudden need of a different crankshaft.
Somewhere along the line of tear-down and leaving the crankshaft exposed in the shop/garage/truck, two of the rod journals have suffered some severe dents/nicks. They look and feel deep enough that I don't believe they will be salvageable. Journals were already .010 under.
So now I await the beatings I so justly deserve and am prepared for my penalty!
That's all I sheepishly know for now...
240 Crankshaft...
I already have the new pistons (.040 over) pressed onto the rods, the block is on the stand, head is ready all set for the 240. If I recall correctly, converting to a 300 would require crank, rods AND pistons.
I did consider upping the motor to a 300, but at the time nothing was bought/assembled. Now that it is, I don't want to eat the cost of the parts.
I did find a guy in my area (50-60 miles away) that has a 240 sitting in a car in his field. He made me an offer I can't refuse! He said I could pretty much have it as no sane person would want a 240 in anything but on the end of an anchor line (my characterization, not his). He's about a month away from pulling it into the shop to begin stripping off what he wants. With that kind of generous offer, I don't want to rush him into something since he's doing me a favor!
I have the front clip off my car and have intentions of removing the rest of the front suspension so I can strip and paint the front frame/cowl panel, etc. I have access to powder coating equipment and I have been coaing the bumper brackets and other miscellaneous parts off the front end. I could continue on this path until he's got the car in the shop/engine out; possibly 4-6 weeks. Then switch back to the engine.
The engine isn't running and I don't know if it will turn over with a wrench. I believe it will require a trip to the machine shop to make it useable so that adds another couple of weeks. So by middle of May, I might be able to reassemble the motor.
If I could locate an inexpensive core, quickly, then I could be rolling again in 2 weeks or so depending on the machine shop timing.
I could let the build schedule slip on the motor since it realistically would not be going back in the chassis until mid May anyway (if all goes as planned; but why would it start now?).
All in all; I'm just angry with myself for screwing up the crank I already had!
That's what little I know for now...
Steve in Flat Rock, MI
66 Custom 500 2 door
C4 trans with B&M shift kit
2 speed wipers and low fidelity AM radio!
Well after making a few inter-web searches and some phone calls; I was able to secure a reground crank .010/.010 for $100 out the door; with no core.
I had some other guys looking around as well and apparently there are still a few of these around. Nobody wants them; but they are around!
I might still take the other member's offer to take the entire 240 engine he has as a spare head and other parts from the car would be good to have as spares (as long as the OL doesn't find out).
LTD
LTD
SR_Crewchief
15
02-24-2007 07:02 PM
The Vagabond
10-15-2002 11:27 PM
charlez
04-03-2002 07:45 PM
