You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I think I have read every thread on here on gearing and fuel mileage. I'm looking at ordering a new truck Lariat F350 8 ft box, 4x4,camper package, 18" wheels and a few other goodies. Trading in a 08 F250 V10 with 4.10 gears 5 Star tune running 87 performance for about 150,000 miles rest of the truck is the same as the one I plan on ordering. I pull open trailers occasionally anywhere from 4000 to 9000 lbs and will throw 2500lbs of feed in the bed and drive to south Texas.
All the threads I read everyone posts up numbers running 60 to 65 showing good numbers on mpg I run 75 to 80. I'm planning on ordering with 4.30 just don't won't to kill the mpg's I know slow down but you can get run over here on these freeways in Houston and the speed limit on the highways is 75mph.
As of right now the truck I have numbers on has 4.30 but I can change that when I call to tell them to go ahead and order just don't now if 4.30's or 3.73's are the way to go........sorry to keep beating a dead horse but help a brother out.
If mpg's are a concern, the 3.73's will do better (which I'm sure you're aware of). Either gear sets will move that weight, the 4.30's will be a bit quicker.
What's more of a priority to you? The savings in gas or a little bit of extra grunt? You gotta pick, you can't have both.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
If you're buying it to tow/haul, get the 4.30 for the max. GVWR rating. You can always swap out for the 3.73. That is, if rating means anything to you. Sounds like you're under 10,000 anyway.
If it were me, and I'm going to be dragging around anything that's not in the bed, then it would be 4.30's.
The 4.30's will give you better mileage and less tranny/engine strain when accelerating while towing. And if the trailer isn't aerodynamic, even more so at highway speeds.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. ®
A while back I did a comparison of the two rear ratios for given speeds. I used an online calculator that asked for final drive, tranny ratios and tire diameter (I used 18" stock dia of 33.17")
1st gear @ 20mph 3.73=3002rpm/4.30=3461rpm
2nd gear @ 30mph 3.73=2631rpm/4.30=3033rpm
3rd gear @ 40mph 3.73=2299rpm/4.30=2650rpm
4th gear @ 50mph 3.73=2174rpm/4.30=2506rpm
5th gear @ 60mph 3.73=1951rpm/4.30=2224rpm
6th gear @ 70mph 3.73=1773rpm/4.30=2044rpm
All this shows is rpm @ given speeds and doesn't take into account real world rpm necessary to move a load at the given speeds...it shows that basically the 4.30 diff will run 1 gear higher than the 3.73 at the same speed after 1st gear. You folks can take this fwiw.
N/A on the 4.10 unless you go aftermarket.
Just get the 4.30's. It's not going to kill your mileage.
Like Matt said, you want a little extra go or an extra 1-1.5mpg?
Thanks everyone for the comments. Just made the call and ordered the truck.
F350 4x4 crew/c 6.2L 172" wb
Sterling Grey
LTHR 40/cnsl/40
Black Int
Lariat
Trailer tow pkg
Sony prem audio
LT275/70bswat18
5"Chrm cab step
Camper package
Body side molding
4.30 gears
Sure wish they would bring back medium wedgewood blue this is three in a row on grey trucks for me, just don't like the colors much. If this truck is as good as the V10 has been I will be a happy man.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
