P1443 97 Aerostar
P1443 97 Aerostar
Sorry, most of us have the older OBDI system and little experience with the newer OBDII system. Here is a link to a similar problem with a '96 Aerostar that may be of help to you.
https://www.ford-trucks.com/forums/s...light=%2Bp1443
Hi, on my 96 which is probably similar to your 97 the evap canister is under the right front fender. It is easy to reach from below. Again as said before, follow the vacuum line to it. If you google it, there are some very helpful videos on Youtube. The hose that goes between the canister and the purge valve is unique being larger on one end than the other. Try not to damage it.
jmccracken1214
09-21-2016 07:50 PM
Sailor_963
04-09-2016 07:36 PM
