Repeated Exhaust sensor problem - Ford Truck Enthusiasts Forums
Old 03-12-2013, 03:51 PM
hwheeler hwheeler is offline
hwheeler is starting off with a positive reputation.
We have a 2012 F 350 built in April of 2012 and have had three different exhaust sensors replaced. These sensors are in differing places along the exhaust pipe system. It has not been the same sensor each time but differing sensors. Their part number is AC3Z-5J213-A. Ford says there's nothing they can do except replace them as they break. Has anyone else had problems with these sensors? The problem is that when they go bad the whole truck stops dead. It is not comforting to know you can break down at any moment. We have now bought an additional sensor in case we break down in the middle of nowhere. The truck only has 12000 miles.
Old 03-12-2013, 08:15 PM
paul100 paul100 is offline
paul100 is starting off with a positive reputation.
I also have a 2012 built in March 2012, delivered April 6th. We had one Nox sensor replaced at 725 miles along with a computer flash. Had the same "DEF system fault" message again around 4000 miles but they only did a computer reflash that time no sensor change, and since then no problems. We have just under 12K miles now.
Old 03-12-2013, 09:06 PM
desertnomad's Avatar
desertnomad desertnomad is offline
desertnomad has a good reputation on FTE.desertnomad has a good reputation on FTE.
I've always been skeptical of these sensors since day 1. Then again just about anything these days has one or more sensors. Hope Ford is attempting root cause of your sensor issues. I've only had the DEF sensor misbehave on me a few times while under 3K miles. Sitting at just over 15K miles, built Dec 2011 and so far no sensor issues. To me having the truck stop dead just because of a faulty sensor is unacceptable. Should at least have limp mode or a way to circumvent when way out in the middle of nowhere and no cell service! Guess if I found a way to circumvent Ford would void my warranty.
Old 03-13-2013, 09:46 AM
jclawns jclawns is offline
jclawns is starting off with a positive reputation.
happened to me 2x, left me on the side of the road with trailer attached both times. if i understood the process correctly when the CPU senses a "bad" reading it will cause you to shut down for a specific timed event. I think it is 60 min. i know its harder to do now than it was but mini max was my solution.60k total on truck and 20k with mini maxx.
Old 03-13-2013, 10:41 AM
blue oval fan's Avatar
blue oval fan blue oval fan is offline
blue oval fan is gaining momentum as a positive member of FTE.
take that exhaust system off with a H&S tuner and problem fixed!
Old 03-14-2013, 09:19 AM
WildWildWest's Avatar
WildWildWest WildWildWest is offline
WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.
Quote:
I've had the NOX sensor go while towing and it is a royal PITA. Previous owner had to replace one as well per the Oasis report when getting my truck fixed in Indianapolis last summer. That's why I bought my H&S MiniMaxx. Haven't deleted yet, but if there are any issues again that rocket ship will be history in a heartbeat!! Possibly sooner if I find new replacement pipes that I like. . Definitely plan on deleting before my next 6,000 mile camping trip so I'm not stranded again.
Old 03-14-2013, 01:15 PM
Native Tex Native Tex is offline
Native Tex is starting off with a positive reputation.
Quote:
I had to be hauled into the dealership here in N. Alabama just last week for the same issue. Got off work, started the truck, it ran about 10 seconds, and then died. After that, if would not even turn over. Dealership sent the old wrecker out and pulled to the shop. Called next morning and it was good to go. I was the sensor on the exhaust side. It totally kills the entire vehicle. That is a crock, especially at 5:00 PM when it is time to go home. All of it was covered under warranty, that was good.
Oxygen Sensor P0056 code wikdwest Excursion - King of SUVs 2 07-19-2014 01:12 AM
EGT Sensor in exhaust cabindoc 6.7L Power Stroke Diesel 37 12-26-2013 08:16 AM
Lack of power TWolf 1999 to 2016 Super Duty 37 07-31-2012 10:32 PM
o2 sensor questions xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 9 12-09-2011 08:45 AM
97 Explorer no start when cold rlr350z Explorer, Sport Trac, Mountaineer & Aviator 6 01-13-2011 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
