leaking oil/engine light
You'll have to crawl over it and under it and snap loads of photos. Post them up here. The next stage is photos.
Crawling all over the engine is part of being a 6.0 owner.
Without pictures it'll be tough to help you. There's a number of things on this engine that if they leak can result in oil dripping toward the rear of the engine.
I am going to discuss the FICM issue with hubby in the AM. I think the way to go is the one recommended above. We had never chipped our truck or changed anything while it was under warranty, but I am thinking now may be the time. Save us a lot of money - even with the premium upgraded FICM. He can handle a simple swap on accessible parts. It will also solve the turbo lag that he hates. Maybe even 1-2 mpg better as well.
My only concern was towing, as the website discussed towing above 8000 lbs. From talking to them, the Ecotune should be the version we need, as we tow up to 12,000 lbs a few times a year. Any comments/warnings on this??
Thanks - will let you know how it works out.
Laura
If you can stand a little downtime, pulling your FICM and sending it in would be the way to go. It's easier than an oil change to get that out on an '07....
Soon we'll be talking batteries, alternators, coolant filters, how to monitor critical systems....
It'll be a party!
Can't comment on the upgraded FICM, but we're somewhat heavy when loaded for a camp trip, so I'd be concerned too....
It'll be a party!
Laura the Atlas 40 will give you better throttle ant turbo response. I also saw about 1.5 MPG increase. The Atlas 40 should be ok for towing that load. BTW Ed offers an exchange program. Call him up and ask about it.
The oil leak could be a few things. But should be easy to find with a little patience. Posting pictures of it would help us help you.
Ok. We are ordering the FICM from Ed via the exchange program. Hubby agrees. Also, there is so little oil on the driveway ( unlike my '97 7.5L with a rear main seal leak ) , that we are going to decline the turbo removal for now, clean up the oil and watch it carefully. (He also has one of those remote camera tools that we can poke around and see if we can see the leak.)
Also going to check out some independant shops locally for future repairs. Will let you know how it goes....
There are local chapters on this forum that you can join.
Regional Chapters - Ford Truck Enthusiasts Forums
You can join one and introduce yourself and ask for recommendations for a good shop in your area. A lot of folks will post something similar as a new thread in this 6.0 forum simply asking if any one knows a good shop in the XYZ area.
The local chapters also have meets and get togethers occasionally. Everything happens at them, from working on trucks to eating fried food.
Too many folks find the bad shops before they find the good ones, and a good mechanic on this engine is where its at. Ed's FICM, bulletproof parts, billet accessories, etc., won't be worth a damn if they are installed wrong.
A lot of us have been there, done that.
#28
X2 on the Chapters there area list of great 6.0 mechanics in each chapter and good choise on Eds ficm you wont be sorry , use the palm of your hand to dissconnect the ficm wires and to replace them I used a piece of 1x2 braced across to snap those little bugrs in use a little diolectic greese that will help the slip in and next time removal, the only hard part for me was the back bolt and the degus bracket I left some hide there to remind me what a pita that spot was lol
#29
