Ranger engine swap - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Ranger engine swap
Old 03-11-2013, 08:46 PM
mtech1950 mtech1950 is offline
mtech1950 is starting off with a positive reputation.
Ranger engine swap
1986 Ranger 2.3, not enough juice. 1986 Thunderbird Turbo coupe, plenty juice. Anyone done this swap? I presume engine, wiring, pcm, maf, from T-bird. Ranger has no a/c so no clearance problems. Prolly use serp belt setup from ranger, mebbe volvo intercooler. What am i missing?
Old 03-12-2013, 08:54 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Trundle on down to the "Performance, Engines & Troubleshooting" section. There is a whole sub-thread on engine swaps. The turbo T-bird is a good and somewhat common swap. Especially if you have a donor vehicle in the back 40 or nearby to snag all the bits & pieces that just seem to go un-noticed until you spot their absence.
I wouldn't bother with the intercooler, unless you plan on mashing on the go pedal a lot. You will be pleasantly pleased with the response without an intercooler.
You might have to up the radiator, as you will be putting out more heat.
Do you plan a complete swap of the long block, or just swapping the intake/exhaust parts? The blocks would be the same, I think. There is a writeup on the Lima in the tech section at the top of this forum.
tom
Old 03-12-2013, 11:36 AM
plqanning to swap the entire motor. oil drainback tube is particular to the tb engine, different injection control, belt drives, all else same....
roller cam conversion. ReggieMiller 1987 - 1996 F150 & Larger F-Series Trucks 3 03-18-2013 05:11 PM
1950 F5 Introduction Aberdale Farm 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 02-22-2013 09:29 AM
1986 Ranger Diesel Brian Hesting General Diesel Discussion 3 04-21-2009 11:22 AM
1986 fuel pump tests sprocketford Ranger & B-Series 0 01-13-2008 05:16 PM
rims on a ranger phish19 Ranger & B-Series 52 02-25-2004 08:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
