Will these tires fit on stock rims?
Hey all,
I'm new to Ford trucks, just bought a 2008 F250 4X4 diesel to replace my old 1/2 ton farm truck. I know this is an old topic, but I am looking at putting larger tires on the truck to fill out the wheel wells, and I could use some advice/experience. The truck has stock 265/70/R17 tires on stock rims. I will not be putting a lift or leveling kit on the truck, and I would like to re-use the stock rims if possible.
Found a reasonably priced set of Cepek 33X12.5X17 truck tires locally, and was just wondering if these tires will fit on the stock rims, and go under the truck without any rubbing. If not, what size of tires will fit on the stock rims?
Thanks for any and all help!
I run 285/75/17 Nitto Terra Grapplers. With the 7.5 rim, it is about as wide as you can go. It is close to 34 inches tall, but I have no rubbing issues at all. They are E rated as well. I think I paid under $300 each with free shipping from Discount tire direct and had them mounted locally.
Yes. It is an 06 with a 5.4. I am pretty sure it has plow prep package. Being the lightest engine and a Super Cab, it is one of the lighter trucks and may ride higher in the front. I can measure from the center of the hub to the fender opening to get the best idea of actual fender opening.
sweet. I'm gonna have to measure mine. Been trying to find the biggest possible size on the stock 17s
