2013 Navi running boards - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 03-11-2013, 06:19 PM
GSDSROK GSDSROK is offline
GSDSROK is starting off with a positive reputation.
My automatic running boards have 3 settings, in, out and auto. The out selection is good until I drive it then they retract and goes back to the previous setting. I would like them to deploy when I open the first door and stay deployed until I drive again (or deploy when I go into Park). The reason is that when I park, I am in and out of the vehicle many times and it is a pain to have them going in and out every time I open a door. Because auto is too irritating, I keep them at the in setting. They return to the in setting after I set them to out as soon as I drive. Any ideas? Does this describe how the out setting is supposed to work?
Jeff
2013 Navigator
Old 03-11-2013, 07:02 PM
Mud Doc's Avatar
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
That's how my 2007 and 2008 worked. Never bothered me if in/out often. Not sure how you would change it.
Joe
Old 03-12-2013, 12:31 PM
Jaylegger Jaylegger is offline
Jaylegger is starting off with a positive reputation.
It's a bit of a peeve for me as well, the only option is to change the setting in the computer everytime you enter exit the vehicle but that is obviously cumbersome. Would be nice to have an in/out button on the door handle that overrides the system when the vehicle ignition is turned off.
Old 03-13-2013, 01:28 PM
Thanks for the responses. I have a response the dealer obtained from Ford. When driven over 5mph, the setting will return to Auto and that is the only method of operation supported. Does not mean it cannot be changed, just means they will not help program if it can be changed
Retractable running boards wills r 2009 - 2014 F150 4 09-25-2015 12:10 AM
2008 Expedition EL Retractable Running Board problem poppadon56 2007 - 2014 Expedition & Navigator 6 08-18-2015 11:09 AM
Battery Drain on 2013 F250 aquasport17 1999 to 2016 Super Duty 4 07-08-2014 09:46 AM
Tell Me About Your AMP Research Deployable Running Boards? ChiefGReid 2009 - 2014 F150 19 10-21-2013 03:48 PM
Platinum Running Boards ggarrahan 2009 - 2014 F150 1 01-25-2010 12:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
