OT - Trailer Backing G.O.A.L.
and i didnt get out and look.
i scraped the corner across the top rail of the chain link fence... and it opened up like a sardine can. if i had not made this miscalculation...
i would not have known about the horrific water damage hiding under the aluma panel siding stuff.
the corner piece of wood was completely rotted away. there was a 2"x2" void in there. 1 8ft stick of treated 2x2 and 2 slightly angled cuts fixed that problem... a tube of white silly cone took care of the cause.
it aint pretty... but it will work till i can get replacement panel parts... (or just renovate and rebuild the back end all together)
hell of it is...
it seemed like i was following the same path i always do when backing it in...
lesson learned...
goals arent just for soccer and hockey...
hell of it is...
lesson learned...
I remember reading an article on vehicle related accidents, article stating that most fender bender type wrecks happen within 3 miles of a person's residence as that's where they feel most comfortable and thus stop really paying attention. I guess this could add to that evidence?
Sucks that happened but apparently it happened for a reason.
Pretty much everything inside works like its supposed to...
Even fired up the hot water heater and the shower worked... kinda low pressure out of the nozzle but it gets the job done... i need to find a new nozzle for it...
We are full timing so I back up the camper often. When I can see the back of the camper from the driver side window, no problem. But when I have to look out the passenger side mirrow I get my wife to spot me. I never understand her motins and gestures, so we have reduced them to: Scream if i'm about to hit something! Works so far.
Its good to go... just cosmetic more than anything...
cool. it wouldn't really be a problem anyway, just glad the damage wasn't too severe for you. what kind of nozzle?
