Floor pans 1959 F100 - Ford Truck Enthusiasts Forums
Old 03-11-2013, 01:12 PM
jamhh's Avatar
jamhh jamhh is offline
jamhh is starting off with a positive reputation.
Does anyone know of anybody other that LMC that build floor pans for a 1959 F100. It would be even better if you know if they are available in Canada. That way the freight is less
Old 03-11-2013, 02:41 PM
nick5446 nick5446 is offline
nick5446 is starting off with a positive reputation.
Subscribing to this. LMC is the only place I've found them, and they're about double what I'm used to spending.
Old 03-12-2013, 06:18 AM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
Old 03-12-2013, 09:47 AM
jamhh's Avatar
beautiful truck. How was the fit? They are priced a fair bit less than LMC? Did you have to replace your front floor braces as well?
Old 03-12-2013, 10:17 AM
jamhh's Avatar
what did you do for a floor in the box. Mine is rough, and replacement floor doesn't seem to exist. I can find a new from Ford floor panel that is the same size (other than mount) but could easily plug and fill them) any suggestions
Old 03-12-2013, 11:05 AM
Walston's Avatar
Quote:
Thanks
They have floor braces as well. The floor pieces are not an exact OEM match, but they work fine.
Like I said, best to call and discuss with them. They are not as internet savy as some suppliers.
Old 03-12-2013, 11:08 AM
Walston's Avatar
My box floor was fine, has a few dings, but not bad. I am sure you could find pickup bed floor that you could make work, but I don't know of any that is made for our trucks specifically.
1959 heater 1959F100-460 1957 - 1960 F100 & Larger F-Series Trucks 11 01-25-2017 04:51 AM
1959 f100 rodriguezfords 1957 - 1960 F100 & Larger F-Series Trucks 9 07-19-2012 02:41 PM
crankshaft dampener / hermonic balancer 1959_f100 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 10 12-15-2011 04:04 PM
1957 f-100 grill 1959 f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-16-2010 04:36 PM
Ford f100 1959 rodriguezfords 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 02-15-2008 11:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
