Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-11-2013, 10:43 AM
mwells mwells is offline
Garage is empty, add now
mwells is starting off with a positive reputation.
6R80 TorqShift fluid change 2010 expy
I have been reading through numerous threads, and find conflicting answers to the question of whether or not is necessary to change the transmission fluid in a 2010 Expedition with 5.4 litre engine and 6R80 transmission. One tech listed the service recomendations which say yes, but the maintenance manual that came with my vehicle states under special operating conditions section [Towing a trailer or using a camper ]:
Every 30,000 miles – Changeautomatic transmission fluid (not required
on 6R60/6R80/TorqShift_transmissions). (I was not able to paste the actual image)
I already have 40k miles on my Expy EL and will be making a 6k mile trip with my 7,000 pound travel trailer (yes I have an auxilliary trans fluid cooler) this summer. Do I need to change the fluid or not?? Thanks for your response.
  #2 (permalink)
Old 03-11-2013, 12:40 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
I have no doubt the oem service intervals are adequate, but here's what I have done on every vehicle (auto trans) that I have owned for 30 years....
At 20k miles, I change the filter (due to possible residual/initial wear particulates that may be floating inside) and either drain the torque converter (if so equipped with a plug) or disconnect the trans cooler line at the radiator, fill the pan with fresh fluid, my wife starts the engine and when 2-3 quarts drain into a bucket, she shuts it off, I refill the pan and repeat until the fluid is clear and in case of the f150, 14 quarts of fresh fluid is in.
I change only the fluid after that (unless I determine substances/contamination in the oil). The intervals vary depending on the type of trans, type of fluid and conditions, but in general, every 30k miles. Heat is a killer on automatic trans fluid and when we lived in the desert area, I changed the trans fluid at the end of summer every year.
In regards to filters, oem is fine, but I typically use Wix.
In regards to trans oil, both in sticks and autos I have always used Valvoline.
I have also never had a trans failure in any vehicle I own and typically keep my vehicles for 10+ years, with over 100k on the odometer.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #3 (permalink)
Old 03-11-2013, 03:05 PM
gaffer222 gaffer222 is offline
gaffer222 is starting off with a positive reputation.
The manual for my 2007 says to change the tranny fluid at 150,000. Curious if yours says the same?
NORMAL SCHEDULE TRUCKS, FULLSIZE VANS & SUVS
150,000 miles
Change engine oil and replace oil filter.
Inspect tires for wear and rotate.
Inspect brake pads/shoes/rotors/drums, brake
lines & hoses, and parking brake system.
Inspect wheel ends for endplay and noise.
Inspect engine cooling system and hoses.
Change Motorcraft Premium Gold Engine Coolant
(see exceptions page 46 and record page 48).
Inspect exhaust system and heat shields.
Inspect steering linkage, ball joints, suspension and,
if equipped, half shafts, driveshaft and U-joints.
Replace engine air filter.
Replace fuel filter (see page 47).
Replace cabin air filter, if equipped.
Change automatic transmission/transaxle fluid
and filter (filter not required on CD4E).
Change rear axle lubricant on all rear wheel
drive (RWD) vehicles (see pages 42 and
46).
Replace accessory drive belt(s) (if not replaced
within last 100,000 miles).
Replace climate-controlled seat filters if equipped
(Navigator and Expedition).
Inspect PCV for flow (3V engines).
Lubricate ball joints and steering linkage if
equipped with zerk fittings.
Replace 4X2 wheel bearings and grease seals,
lubricate and adjust bearings.
Inspect and lubricate 4X4 front axle shaft U-joints
(F250/350/450/550).
Change front axle lubricant (4X4 only).
Change transfer case fluid (4X4 only).
Exception below:
Items Needing Special Attention
If you operate your Ford/Lincoln/Mercury
primarily in one of the more demanding “Special Operating
Conditions”
listed below, you will need to have some items maintained more frequently. If you only occasionally
operate your vehicle under these conditions, it is not necessary to perform the additional
maintenance. For specific recommendations, see your dealership service advisor or qualified service professional.
Towing a trailer or using a camper or car-top carrier
Every 3,000 miles or 3 months
Every 30,000 miles
Change automatic transmission/transaxle fluid (not
required on 6R60 transmission)
Every 60,000 miles
As required
Change manual transmission fluid
As required Inspect and lubricate U-joints
  #4 (permalink)
Old 03-12-2013, 08:02 AM
reply to gaffer222
Yes, basically the same.
Change automatic transmission fluid and filter
(filter not required on 6F35). (Except vehicles
equipped with the TorqShift transmission).
Hoping for a response from a Ford tech.
  #5 (permalink)
Old 03-12-2013, 08:11 AM
Thanks to Beechkid
Thanks for your response. I gave up DIY fluid changes some years ago, so am looking at some expense to accomplish this task. The Ford dealer says they do not drop the pan, and replace the filter, but do a flush. I don't mind paying for this if it is necessary and I need to for extended warranty compliance. I really want to resolve the conflict between the service indicated by the Ford tech and the Ford maintenance manual which came with my truck.
Thanks to all for responding.
  #6 (permalink)
Old 03-13-2013, 11:58 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
You have the 6r80 trans on that truck. They don't want to drop the pan or change the filter because they are lazy.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #7 (permalink)
Old 03-13-2013, 12:02 PM
gears351's Avatar
gears351 gears351 is offline
gears351 is starting off with a positive reputation.
Shop by me wants $110 for a fluid/filter/flush/change - I trust this shop and think it's a good deal as the one writeup I found on someone doing this service themselves spent $104 on just the parts......
  #8 (permalink)
Old 03-13-2013, 12:19 PM
berry1234's Avatar
Quote:
Hmm. Sounds too cheap. Why do a job for a loss? Make sure they are using the correct fluid. Some shops chinse out and use a low grade bulk tranny fluid. Look in your manual for fluid type. I think it's Mercon SP, 11 quarts.
__________________
  #9 (permalink)
Old 03-15-2013, 07:50 AM
gears351's Avatar
my owner's manual specs Mercon V - I'd like to go synthetic but it's possible MV is synthetic (I know that's the case with Chrysler's newer ATFs) And the shop is reputable, I've used them with good results in the past. But you're right - making sure it's the correct fluid is important.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
