87 Ford F-150 2WD Dual Tanks Wont Start
I have a 87 Ford F-150 with a 4.9L it has dual tanks, The problem is it won't start. I've replaced the fuel filter, external fuel pump, and a fuel tank switching valve (thats what I was told it is called, its a black fuel resevoir bolted to the frame, it doesn't have a motor, it has four lines going in and two going out) Anyway, I have replaced those three things and it still doesn't start, I know the fuel pumps work because the fuel will get to the switching valve. However when I unplug the fuel line after the switching valve no fuel comes out just a couple drops. I really have no other idea, I even tried the fuel shut-off switch under the dash. Any help you could give me would really help. I'm in the military and this is my only piece of transpotation, the military doesn't get paid much so anything will help..
Well I know the fuel is getting to the switching valve and I can hear the fuel pumps turn on when I turn the key.
It kinda looks like this:
[fuel tank]--[fuel tank]--[switching valve]--[external pump]--[filter]--[engine]
well if that makes any sense... thats the setup
Any other cause for no fuel??
Yes, I can hear both pumps the intank is really loud and the external pump is a small whine, after I unplug the fuel lines from the resevoir only a few drops come out... even when I crank the engine nothing comes out... when I unplug it I can hear the pressure leaving, but no fuel. When I pour gas into the throttle body it will run so I know I'm getting spark?? Any other ideas??????
Originally posted by radengd
...there is pressure...
fordf1501991
19
05-30-2019 06:32 PM
JasonVoor
09-09-2014 03:19 PM
CaptMorgan
05-23-2010 05:32 PM
