1956 Ford COE - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1956 Ford COE
Old 03-10-2013, 11:07 PM
Damion Anderson's Avatar
Damion Anderson Damion Anderson is offline
Damion Anderson is starting off with a positive reputation.
1956 Ford COE
Hello, I just purchased a 56 COE and I am beginning to look for parts. At the moment I really need the U Joint caps and bolts to hook the drive shaft back up. The guy I bought it from lost them. I am assuming the bolts are probably at least a 10-12 grade? It has the eaton back transaxle. Does anyone know if I can possibly find these locally at a commercial truck shop or if I need original hardware? I am also looking for the right side fender steps and a back window. I am sure I can get some glass cut but I would love to have the fomoco stamp on the window. I was also wondering if it was standard to have no door lock on the drivers side door? My truck has a lock on the passenger side but nothing on the drivers side. I appreciate any info anyone wants to share as this is my first COE. I am in Oregon and would also love to meet some other COE owners if there are any around. Thanks in advance and all the best, Damion
Last edited by Damion Anderson; 03-10-2013 at 11:18 PM. Reason: figured out how to upload pics
Old 05-17-2014, 10:29 PM
T8ter's Avatar
T8ter T8ter is offline
T8ter is starting off with a positive reputation.
Pictures Please.. of truck...........
Old 05-30-2014, 09:24 PM
Tomc750 Tomc750 is offline
Tomc750 is gaining momentum as a positive member of FTE.
No lock on the drivers side is the norm. As far as the driveshaft hardware is concerned, a driveshaft shop should be able to fix you up, or hit a junkyard. The hardware is the same as a newer truck.
Old 05-31-2014, 05:04 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
It has the Eaton back transaxle.
Transaxle only used with front wheel drive, do you mean an Eaton single or 2 speed rear axle?
1948/56 Ford Truck Parts Catalog available on a C/D from hipoparts.com.
These parts you're asking about are obsolete, but may be available NOS. But first, I need to know...
There is more than just one series of COE's, which COE is it? C500 - C600 - C700 - C750 - C800 - C900?
Once I know which COE you have, I'll post the parts catalog pic that shows the driveshaft and attaching parts.
Back glass same .. all 1953/56 trucks except panels and P Series Parcel Delivery. You will most likely need a new weatherstrip, reproduced, available from all the repro parts sellers.
For many years, it was standard operating procedure to lock the left door, then slide over the seat, exit the right door.
Many streets did not have painted divider lines, traffic was chaotic with vehicles whizzing all over the place, so automakers didn't want people to exit the left door then step out into traffic.
By the 1950's, things began to change. 1955/56: Custom Cabs came with R & L door lock cylinders, Standard Cabs only came with the R/door lock cylinder.
FTE has an OR Chapter and a WA Chapter, I suggest you join both. The OR Chapter leader is fabmandeluxe who is also an FTE moderator. I believe he lives in the Baker area.
Old 05-31-2014, 11:18 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Pic's please
How to now post pic's on FTE
New Photo Uploader : A Picture Guide.
http://www.ford-trucks.com/forums/13...ure-guide.html
Old 06-04-2014, 01:51 PM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
If you have the U-joint itself, you could take it to a parts store that handles truck parts (most NAPA do) and they might be able to match up what you need, or look it up in one of the paper catalogs. These have not changed much over the years and are available.
Old 06-04-2014, 01:57 PM
And be careful of bolt grade. Stronger is not necessarily better. I see grade 5 and 8 hex head often used for attaching U-Joints. Be careful of grade 12 (a metric grade, primarily socket head) as they are more brittle than grades 5 and 8 (in inch series).
WTB 40's Early 50's COE Cab and Front end Hughmullersa WTB - Parts & other 0 03-20-2015 09:18 AM
New to you c-jet New Member Introductions 0 10-25-2014 01:06 PM
1940 COE parts 1940 coe 1947 and Older Ford Trucks 0 10-05-2012 04:32 AM
Sleeper needed 69 tdega Large Truck 11 05-02-2010 11:16 AM
Oregon C800 COE ??? robertr 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 06-28-2005 09:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
