Radius Arms - Ford Truck Enthusiasts Forums
Radius Arms
Old 03-10-2013, 10:51 PM
YooperUno YooperUno is offline
YooperUno is starting off with a positive reputation.
Radius Arms
Ok folks have another one for ya one of my radius arms is wore out can a guy weld it and have it machined down or should u replace it and if I have to replace it where can I get one 1977 Ford F-150 thanks again
Old 03-10-2013, 11:54 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Show use some courtesy and use punctuation. Run-on sentences are annoying to alot of us.
To your question... 2WD or 4WD? Try filling out your signature so we know what your working with and we don't have to ask you that question.
Either way, a salvage yard is your best bet.
Old 03-11-2013, 05:23 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by YooperUno View Post
Ok folks, have another one for ya. One of my radius arms is wore out, can a guy weld it and have it machined down, or should u replace it?
If I have to replace it, where can I get one: 1977 Ford F150 4WD
Please, when asking questions, list all the pertinent info. I read thru some of your other posts, discovered your truck has 4WD / 2WD parts are not the same!
D6TZ-3A360-A (replaced C6TZ-3A360-A & B) .. Radius Arm ~ Right/Left is the same / Obsolete
Applications: 1966/76 F100 4WD / 1966/77 Bronco / 1975/77 F150 4WD
No Ford Dealer or obsolete parts vendor has any.
C6TZ-3A360-A =
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
Try broncograveyard.com for a user.
Old 03-11-2013, 10:58 AM
wdfp wdfp is offline
wdfp is starting off with a positive reputation.
I saw U-haul on ebay has 2 new ones but they must be 2wd as the # is the same except for the last letter which is a C.
Old 03-11-2013, 12:29 PM
Hey folks thanks for the info
Sorry about the info will take care of that problem. Will do a better job next time.
Old 03-11-2013, 03:12 PM
Rossta86 Rossta86 is offline
Rossta86 is gaining momentum as a positive member of FTE.
The areas where the bushings ride at the frame mount end of the radius rod were "wallowed" out on my 1978 4WD F150. I laid down a few beads and then ground the welds down smooth. I have had no issues thus far, but I would hate to see the aftermath of a failure, therefore take my advice at your own risk.
Old 03-12-2013, 05:21 AM
1978/79's use different radius arms. Notice that the applications for D6TZ-3A360-A are 1966/77.
Quote:
No such Ford part number of D6TZ-3A360-C / Look at it again, it's either D4TZ-3A360-C or D8TZ-3A360-C .. as these are the only radius arms used in the 1970's w/a C suffix.
Neither is correct for the OP's truck.
Old 03-12-2013, 02:44 PM
Probably an error on their part then, I imagine when you list that many parts it would be easy to make a mistake
Ford Arm D6TZ3A360C | eBay
You may need to copy and paste that link but I tried it and it takes you right to it
Old 03-12-2013, 06:32 PM
Hey wdfp that part isnt what I'm looking for its a radius arm but not the one I'm looking for thanks anyway
Hey NumberDummy quite a handle but I hear where your coming from. So what u r telling me then 1975/1977 F-150 4WD r the only ones that will fit my truck.Thanks
Old 03-12-2013, 08:04 PM
So what are u r telling me then 1975/77 F150 4WD r the only ones that will fit my truck?
Quote:
Applications: 1966/76 F100 4WD & 1966/77 Bronco & 1975/77 F150 4WD
I removed the dashes, replaced them with ampersands: Does this make the applications clearer?
Questions about changing the radius arm bushing on E350 reem98 1968-2013 Full Size Vans 8 08-13-2015 01:15 AM
2wd radius arm bracket? indebt 1999 to 2016 Super Duty 4 06-04-2009 09:42 AM
radius arm bushing for 67 f100 kbak 1967 - 1972 F-100 & Larger F-Series Trucks 6 12-21-2006 07:03 AM
radius arm bushing replacement warema 1978 - 1996 Big Bronco 10 12-08-2003 11:00 PM
radius arm bushing mounts maison302 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-17-2001 12:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
