74 & 76 frame compatibility
Old 03-12-2013, 04:28 PM
Canus's Avatar
Canus
Canus is offline
Will be buying a 76 2wd long bed as a parts vehicle (need doors, bed, one fender, etc.) for the 74 2wd long bed I am restoring. Does anyone know if the frames are interchangeable? Will finish the build on the 74 and if the frames will interchange as time and money allow I plan on doing the Thunderbird rear independent suspension and Crown Vic front suspension on the 76 frame then swapping drive train and body parts over.
Old 03-12-2013, 04:50 PM
redroad's Avatar
redroad
redroad is offline
They are both 2wd and same F250, F150 ? If so no difference
Old 03-12-2013, 04:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Yes, they are the same.
One warning though, if you do plan on using the '76 at a later date be sure you keep the title for it. If you do a body swap, most states require the frame VIN be used for registration, not the VIN that's on the warranty plate.
Old 03-12-2013, 06:20 PM
Canus's Avatar
Canus
Canus is offline
Mike,
Thanks for the reminder. I will be getting the title with the 76.
EricJ
11-28-2016 05:33 AM
66_fairlane_xl
06-01-2013 05:08 AM
darkpurp1e
08-11-2012 01:55 PM
frazier23
12-04-2011 04:05 PM
maverickman514
05-18-2011 09:18 AM
Quick Reply: 74 & 76 frame compatibility
