Vin decoding? - Ford Truck Enthusiasts Forums
Vin decoding?
Old 03-10-2013, 09:19 PM
6cannons 6cannons is offline
6cannons is starting off with a positive reputation.
Vin decoding?
Trying to decode vin on my 66
Everywhere says not valid?
Vin is f10bc748107
Old 03-10-2013, 11:46 PM
found what i needed
just had to ask at the right place
Old 03-11-2013, 02:08 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 6cannons View Post
Trying to decode VIN on my 66. Everywhere says not valid? F10BC748107
F10 = F100 2WD
B = 300 1V I-6.
C = Oakville Ontario Canada Truck Assembly Plant.
748107 = 1966, assembled September 1965.
Automakere went to 17 digit VIN's in 1980/81. Some online decoders do not recognize 11 digit VIN's.
Old 03-11-2013, 08:21 AM
thanks numberdummie i found the tag on the door
is beat up bad i can make out the raised numbers lust not what they mean
they are in this order
any help would be awsome
129 jh e b1 f ab
5000 150 3600 b7
i just bougt the truck two weeks ago and im tring to learn all i can about it
before i start work on it
Old 03-11-2013, 08:47 AM
I found the tag on the door, it's beat up bad. I can make out the raised numbers, just not what they mean.
Identified them for you.
W.B. 129 / COLOR: JH / MODEL: F100 / BODY: E81 / TRANS: F / AXLE: A8 / MAX GVWR LBS: 5000 / CERT NET HP: 150 / RPM: 3600 / DSO: B7
129" Wheelbase.
JH: J = Rangoon Red / H = Sahara Beige.
F100 2WD, 5,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
F = Borg Warner T-18 4 Speed Manual Transmission.
A8 = Dana 44 Rear Axle / 3.54-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
B7 = Ford Motor Co. of Canada Ltd., Pacific Lincoln-Mercury District Sales Office, where the original selling dealer ordered the truck from.
You omitted the MODEL code, I added it based on the GVWR
vin # decodeing Rangerdanger33 Ranger & B-Series 12 07-18-2005 07:37 AM
VIN Decoder oppy 1967 - 1972 F-100 & Larger F-Series Trucks 16 12-30-2003 04:18 PM
vin decoding revisited............. masterbeavis 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-06-2002 11:38 PM
Ford VIN carllouis Expedition & Navigator 1 06-15-2000 02:38 PM
VIN Decoder jowilker 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-20-2000 02:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
