1982 F250 no spark
1982 F250 no spark
Battery wasnt tied down good enough and let go and fell off the tray backwards and broke a plastic mount of the passenger side inner fender. there are 2 screws, one has two wires conected to it and the other screw had one wire. the bottom of the screws were touching some kind of copper plate. what exactly is this piece? simply putting the wires together gave me absolutely no spark either.
Put pictures of it in your Album here and either use the IMG code to make them show up in your posts, or else give the link to your Album.
Ford Truck Enthusiasts Forums - boggmaster's Album: Garage - Black Bird - Picture
Got to look at it again today. I have headlights but no dome light. I also have power at the coil, but nothing at the coil wire connecting to the distributor cap. Could the battery breaking that piece be related to a bad coil? There are 2 wires on one screw and one on another. One goes to the starter solenoid, one to the radio, and the third is a thicker orange wire that runs down along the frame and is then cutoff with nothing attached and no connector
Take your meter and poke around the fuse box. There should be a group of fuses that have battery voltage all the time. With the key in run, most all the fuses should have 12v.
There is a fat yellow wire that comes from the starter solenoid area, goes through the firewall, and goes over to a splice. At this splice it splits up, on branch feeds the ignition switch and the other branch feeds the hot all the time part of the fuse box. You need to see if this yellow wire is still good.
The headlights are fed from a splice under the hood near the solenoid, up near where the yellow wire is fed also. The headlights work, so that is telling us part of this circuit at the very start is working.
If you are getting power at the fuse box, then that tells us the main yellow wire is good.
smiler289
21
04-03-2017 06:53 PM
rwkinch
10-14-2012 07:14 PM
Lefty980
10-01-2012 09:22 PM
navigatorstang
11-28-2010 05:59 PM
