Thumping when brakes applied. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-09-2013, 05:14 PM
modfan modfan is offline
modfan is starting off with a positive reputation.
My 06 F350 King Ranch has a severe thumping when brakes are applied. Bad enough that the entire truck shakes. I have put on new rotors, calipers, and pads on the front. Any help would be appreciated.
Old 03-09-2013, 06:23 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
check the driveshaft slip joint.....if its a one time thump..Tell me more about the noise /feeling etc.
The rears will do the same thing if the rotors are bad.
Old 03-09-2013, 08:42 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Completely agree here, what makes you think the problem is in the front?
Old 03-09-2013, 10:43 PM
I didn't say I thought it was in the front. I said that I had changed the rotors calipers and pads. This is because the rotors were warped and calipers were froze. After the change this problem started.
Old 03-09-2013, 11:42 PM
We still don't know enough! All we were saying is rears will cause the same issue..If you are talking about brake pulsations from rotors...So is that what it is?? You hit the brakes and the pedal pulsates until you stop? Thumping is not a word normally used to indicate rotor runout so I was trying to get more info from you.
If you still have brake pulsations your rotors are messed up again...How long did it take them to go bad?
Old 03-09-2013, 11:49 PM
I thought that it could be a bad rotor or a broken rotor. The new parts were put on. About 500 miles or less sence install. Could be a bad rotor? Just would like to know what to look for next. I checked the rears today and found nothing wrong.
Old 03-09-2013, 11:50 PM
I thought it felt like a broken part rather than a warped rotor. Could it possibly be a problem with the ABS?
Old 03-10-2013, 12:00 AM
Sure could be if it pulsates until you stop. Check the rotors, really can't be anything else.
Cheap rotors fail quick. Also you could have a bad new caliper...Jack up hit brakes/ let off see if wheels turn easy..by hand.
Old 03-10-2013, 07:00 AM
fmtrvt fmtrvt is offline
fmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to all
You could have a rotor that was machined improperly. The reason all rotors pulsate is uneven thickness between the two rubbing surfaces, typically it is worn in. They do not "warp" from heat.
However, you can also have a rear issue as noted, only noticed until now because it would take some time for the new front brakes to bed in and develop full stopping power, so the work balance is thrown towards the rear brakes. The best way to test this is to use a pair of hose pliers to pinch off the drop hose between the frame and rear axle when you are on a deserted road and make a few stops to see if the pulsation is still there with front brakes only.
Old 03-10-2013, 07:57 PM
Thanks everyone for the helpful replies. Jacked up the fronts and spun the tires, NO VIBRATION. Did as suggested and pinched rubber line in the rear and took it for a ride. NO VIBRATION. Found a cracked rotor in the rear!!!!!! Also one of the calipers was froze. Brake pads are rusted in place. Thanks again everyone!!!!
Blinkers flash fast when brakes applied 2inthewind 2004 - 2008 F150 4 01-05-2014 10:57 AM
King Ranch Leather Conditioner wreedZ71 2004 - 2008 F150 13 02-19-2008 03:26 PM
Thump sound on driver floor when brakes applied Raptorman 1999 to 2016 Super Duty 7 02-16-2005 07:42 PM
Brake questions Will_01_GT 1978 - 1996 Big Bronco 2 02-22-2004 11:48 AM
Brake Thump Monsta 1999 to 2016 Super Duty 5 05-17-2002 09:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
