Almost rid of all my engine codes
#32
Closed Throttle = -1
Part Throttle = 0
Wide Open Throttle = 1
The three things the computer deals with the TPS are as said above is closed throttle, part throttle and wide open throttle.
When you turn on the key the computer will save this voltage level as CT or closed throttle.
As said above when the voltage (TP) is 0.04 volt above Closed Throttle the computer will go into part throttle mode.
When the voltage (TP) is 2.71 volts above Closed Throttle voltage level the computer will go into Full Throttle mode.
#33
I got the Motorcraft TPS today and installed it when I got home. I was excited when I saw that it was testing at .75 at idle and 4.4 at WOT (the duralast brand would only get to 3. something). Started it up and it sounded great, ran the codes and got a system pass. Took it for a test drive, now it's shifting even earlier! It shifted into overdrive at 30 mph... What the heck is going on here? It's frustrating because it's running so good, now it wants to shift weird.. I swear if it isn't one thing it's another.
#34
#36
The PCM computer as all computers operate on logic levels. There are three logic levels to the TPS, -1, 0, & 1.
Part Throttle = 0
Part Throttle = 0
#37
#38
Since you disconnected the battery, the computer has to re-learn itself all over again.
What you're experiencing is the (for lack of a better term) "pre-set FORD program" in the computer.
Drive your truck around for a half hour or so, in town/stop and go traffic would be wise, and it SHOULD start shifting correctly.........
You're there, just give your truck a little time !!!!
Bob
#39
IIRC there is a pre-programmed "start routine" in the PCM that most likely uses a pre-set value(s) when the key is turned to start.
I may be off base here, but I seem to remember reading that. Thank you Ian !!!
Bob
#40
Thanks and I will set proper voltage. No need to go through the code even when you have time, was just thinking you knew already. Guess I found a limit.
#41
#42
Which TPS "on the left"? Upper or lower? Or do you mean the diagram on the left that's at the bottom of the page?
And which notch are you talking about?
#43
I realized the view is probably looking at the sensor and I was looking at the connector. I'm accustomed to looking at the connector view as I see on many other eec diagrams I've seen or downloaded. I didn't see on that site where it said what view that was.
#44
In the image you linked to it says sensor right above the diagrams.
I just pulled a sensor and looked at the sensor plug and the tab is in the right place with the diagram you linked to.
The diagram does not show the slide on mounting clip tracks but the rest is correct.
The wire colors are not displayed for the sensor if you wanted to bench test the sensor and they are:
VREF = ORANGE = +5VDC FROM COMPUTER
SIG RTN = BLACK = GROUND THROUGH THE COMPUTER TO THE NEG POST OF BATTERY
TPS = GREEN = THROTTLE POSITION INFORMATION TO COMPUTER
#45
Figured I would give a final update. The truck is running great, feels and sounds brand new. Just put gas in it today and did the math. I went from 7 MPG to 11 in the city. My all highway MPG is still unknown. But to jump 4 MPG in city driving, that's going to be 70 or more miles per tank than what I'm used to. This will save me a ton of money in the long run, especially the upcoming road trip. Thanks for all the info.
