300 I-6 Rocker Studs - Ford Truck Enthusiasts Forums
Old 03-09-2013, 01:09 PM
F-4 GUY F-4 GUY is offline
F-4 GUY is starting off with a positive reputation.
Hi, I am trying to find out when ford changed stud sizes on the 300 I-6. My 77 came with self locking nuts. I need a valve job and I picked up another head which has smaller non-locking nuts and jam nuts. I can't make out the code on the head and am trying to figure out when they changed so I know the year of the head. They both have adjustable rockers and hopefully will interchange. Thanks in advance.
Old 03-09-2013, 08:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
According to the Ford parts catalog 73-77 used studs with 3/8"-24 thread. In '78 they switched to the smaller 5/16"-24 thread.
Old 03-10-2013, 05:27 PM
Thanks for the quick response. That helps alot.
Old 03-11-2013, 07:36 PM
Quote:
Are the pushrods the same?
Old 03-11-2013, 07:51 PM
mikeo0o0o0's Avatar
Quote:
Yup, the catalog shows same pushrods 73-79
Rocker Stud Sizes F-4 GUY Ford Inline Six, 200, 250, 4.9L / 300 1 03-06-2013 09:49 AM
Dealing with a worn rocker arm stud zerfetzen Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-19-2012 08:11 AM
Dealing with a worn rocker arm stud - SOLVED zerfetzen 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-18-2012 07:37 PM
429 rocker arm nuts and bent pushrods Shelby Sam Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 04-10-2004 01:10 PM
rockers knocking tweakingit Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 11-03-2003 09:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
