1994 5.0 swap to 5.8
Need a little help or advise, i got a 1994 xlt 2wd 5.0 with 4r70w trans and i want to swap in a 5.8 iv heard its really easy my question is what do i need for the swap and can i still use the 5.0 wiring harness/ computer and will it bolt directly to the trans. any help or advise will help thank you
The transmission will bolt right up but you will need a different flexplate that goes with a 351, something about the balance. The motor mounts is a direct bolt in, will match right up. The heads are 2 inches farther apart on the 5.8 so this will cause some concerns if you have a single exhaust off the manifolds. The heads being 2 inches farther apart will also probably create some minor problems where the belt driven accessories bolt to the front of the engine.
Someone else will have to advise you on the computer and wiring harness.
dylanellis
09-12-2021 11:48 PM
