1960 F250 4x4 Project - Ford Truck Enthusiasts Forums
Old 03-08-2013, 11:30 PM
NateTheGreat NateTheGreat is offline
NateTheGreat is starting off with a positive reputation.
All,
I have posted on here a few times but thought I would come and post again since I'm actually starting my build (finally).
I've got a 1960 F250 4x4 that I bought from the 2nd owner. I bought it because the body is immaculate. Very straight, with only the most minor surface rust. Some pics:
Anywho, so I finally moved into a house with a garage () which allowed me to start building. I've gotten the thing basically all the way torn apart. The only thing left on the chassis is the cab, which is stripped (no doors, seat, tank, wiring, etc.). My engine is on a stand, the tranny and transfer case are on a bench.
That being said, I'm ready to start rebuilding them! But now I'm struggling to find parts. I've been desperately trying to find a bearing, gasket, and syncro kit for the T98a tranny and a bearing and gasket kit for the DS 24 transfer case. www.cobratransmission.com has some of the parts but the syncro kit is out of stock and I don't want to have to order it in stages.
I also need a full rebuild kit for the 292. Northern Auto has some but not sure where is the best place to go. Any thoughts?
Also, I want to do a power/disc break conversion up front and don't think that anyone makes a kit for the 8 lug axles (I've searched and searched and can't find one). Is that true?
Finally, I want to go to a 4 barrel carb but don't know where I can get a 4 barrel IM for the 292. Any ideas?
I know it's a lot of questions right away but I've been sitting on this long enough and am ready to get some serious work done. Thanks!
Old 03-08-2013, 11:47 PM
napass2004 napass2004 is offline
napass2004 is starting off with a positive reputation.
Well Jeff's bronco graveyard has the bearing and gasket kit for the dana 24 I'm not sure if they have the t98 rebuild kit but perhaps. Blackbirds customs makes a disc brake kit for the early dana 44 or you could switch to a newer axle like I'm doing to get disc brakes. John mummert makes everything y block they'll have the 4bbl intake you'll want and they have rebuild kits. Good luck with the build post your progress
Kyle
Old 03-09-2013, 12:26 PM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
All I can say is sweet. My 65 looks like the younger brother of your truck.
Brothers from the same father Old Henry.
Old 03-09-2013, 01:43 PM
Same here I have a 61 4x4 frame under my 64 f250
Old 03-09-2013, 02:25 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Good to see you Nate. Take lots of pictures during your rebuild and share them with us.
PS I bought my bearings and seals for the transfer case from Rockauto.
Old 03-10-2013, 01:12 PM
FJones8668 FJones8668 is offline
FJones8668 is starting off with a positive reputation.
I have no experience with these guys but maybe this rebuild kit is what you are looking for.
Borg Warner T98 4 Speed repair parts and overhaul kits. - Drivetrain.com
Old 03-10-2013, 02:49 PM
chetspencer's Avatar
chetspencer chetspencer is offline
chetspencer is gaining momentum as a positive member of FTE.
NICE TRUCK!!!!
Old 03-10-2013, 09:50 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
thundersnow70 is starting off with a positive reputation.
am i still in the fridge zone or did i click on the slick tab? JK, nice looking trucks guys. you might want to check evilbay for the intake. i think any 292 4brl intake will bolt on. ford car if i recall. my intake came out of a t-bird i believe. good luck with it.
Old 03-11-2013, 07:47 AM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
Have you checked with a local auto parts store? I have a relatively current Federal Mogul catalog and they list several bearings and seals.
They show Ford F250 48 to 64 as the years.
Input shaft bearing 308-L1
Mainshaft Seal 450308 bearing 308-L
Mainshaft pilot W-1590-Q
Countershaft bearing C-436-Q
Reverse Idler bearing Q-6283
2nd speed gear bearing Q-6086
They also show seals and bearings for the 59 to 65 Spicer 24 transfer case.
Old 03-15-2013, 01:36 AM
idaho211 idaho211 is offline
idaho211 is starting off with a positive reputation.
Welcome. John Mummert has a rebuild kit for the 292 that is reasonable.
The stock 4 barrel iron intake is a good choice. Find one with the B suffix so it will fit the later carbs. A good choice is the Holley 1848 4 barrel. It is a stock replacement and is set up to match your acc linkage. Available at Holley new. Recommend going with a 5 blade fan, and pointless kit for your distributor. These are good trucks especially hard to find one without rusted out floors, fenders. Let us know how it is going.
Old 10-26-2013, 05:25 PM
Klaus_N Klaus_N is offline
Klaus_N is starting off with a positive reputation.
hi there, new to this forum.
i am just about to pull the trigger on a 1960 f250 4x4, it's been sitting a while and needs full restoration
any suggestions before i hand over the $ to the seller, things to look out for ?
any help would be welcome, thanks
Old 10-26-2013, 05:44 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
1957 Ford/Merc/Thunderbird 292/312, 1958/63 Ford/Merc 292. 1954/56 cars use the Holley 'teapot' 4V, the carb/intake bolt pattern is different.
Old 10-26-2013, 07:42 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Holley 'teapot' 4V. AKA "The Flame Thrower".
It's in it's best on a shelf under class in a Museum.
It's not made for Automotive Combustion.
Old 10-27-2013, 02:18 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
That is a beautiful truck you have there. Most old 4x4s were beat to heck in their early years. Congratulations on your find!
Old 10-27-2013, 07:06 AM
1958 Ford F250's Avatar
1958 Ford F250 1958 Ford F250 is offline
1958 Ford F250 is starting off with a positive reputation.
Smile 1960
Quote:
Originally Posted by NateTheGreat View Post
All,
Hi, Nice Truck !!! I also have a T98 on my 58 F250 and I did once see a bearing,gasket & syncro kit on EBAY but I just looked and I do not see it thier. I also have a 292 Y Block 4.8L and EBAY does have the full Rebuild Kit for it, go to EBAY and hit advanceed search and punch in ITEM# 141099922136. OK
Jacks 65 Build Jacks 65 1961 - 1966 F-100 & Larger F-Series Trucks 74 10-07-2015 08:27 PM
Roll-X & Bakbox 2 Review LaxinFish29 Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners 6 03-21-2014 01:19 AM
What is the best way to take care of this rust? kickstand03263 1999 to 2016 Super Duty 8 10-06-2013 02:29 PM
Aftermarket Exhaust LaxinFish29 6.2L V8 9 09-03-2013 08:36 PM
Galaxy Tab 2 10.1 in Navigator chp10_8 1997-2006 Expedition & Navigator 3 04-29-2013 03:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
