3rd door stuck - Ford Truck Enthusiasts Forums
3rd door stuck
Old 03-08-2013, 06:17 PM
krzldy1949 krzldy1949 is offline
krzldy1949 is starting off with a positive reputation.
3rd door stuck
Hello - I have removed the panel cover; cables are out - door is still stuck! Is there a way to release the latch? It is the driver side back door - 2001 Lariat. Thanks so much
Old 03-08-2013, 09:21 PM
kspeck kspeck is offline
kspeck is starting off with a positive reputation.
My passenger 3rd door was stuck, I removed the panels and there are 2 cables, 1 cable had become un anchored, for the lack of the technical term, I was able to use a Wire Tie and re anchor it.
As far as I know the cable is the only way to open the door, you will probably need to replace them.
Old 03-08-2013, 10:40 PM
Thanks for the response - the cables are out! Tried pulling the cables inside the case and that didn't work. Now the door is latched. There must be a wasy to open latch. Can't get the door open. Thanks
Old 03-09-2013, 09:52 AM
I thought maybe the Ford genie would get the door open but he never showed up! What can I do please help?
Old 03-09-2013, 12:39 PM
3rd door stuck driver's side - how to open stuck door
I got it - maybe keep this in how to? After removing the door panels and the two cables I found that the end of the cables had deteriorated to nothing. The top latch was holding my door shut. Under the weather stripping you can see the mechanism. The big latch has a spring next to it and there is an L shaped metal piece. Get a double wired clothes hanger and push on the little spring that is next to the latch - you have to push down, and the latch will open. I can email a pic or try this F150online Forums - R8rvectors's Album: Rear Door Upper Latch - Picture
Door stuck shut powerstroker100 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2015 01:18 PM
Door handle stuck StealthWyvern 1987 - 1996 F150 & Larger F-Series Trucks 5 11-21-2014 07:16 PM
open door sensor malfunctioning icentropy Excursion - King of SUVs 14 02-19-2014 12:57 PM
Air / Vent door stuck on vent 2011 f350 Fireater1968 1999 to 2016 Super Duty 2 11-23-2013 05:03 AM
Stuck crewcab door broken cab lights. nateairman 1994.5 - 1997 7.3L Power Stroke Diesel 3 02-18-2012 04:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
